subscribed - for reference
this should be a sticky!
+1!!!subscribed - for reference
Thanks joe, comparing two japanese steels here I was surprised to see vg-1 ranked so much higher then sg2 when it's hardness and composition are quite different. I agree sg2 works well in thin edges with good edge stability due to it 62-63 HRC.
Hey Gine. My guess about the VG1 in particular would be the coarser grain structure cutting the fibers better or longer in this case. It's very much like 19C Sandvik steel and it has mostly coarse chrome carbides with no powder process or anything that really contributes to smaller grain structures. It's sort of the reason D2 knives make good hunting/skinning knives as it saws through hair, skin and flesh better than a super fine grained steel. Once again I'm just speaking generalities. VG1's performance above SG2's doesn't necessarily make it better steel overall. Not unless wear resistance on this type medium is the only way you grade steels for personal use. This is a great indicator of differences in abrasive wear resistance but shouldn't be the only way steels are selected.
I've seen the edges on the knives that Jim uses and he really does make things as consistent as he can. If he says something I tend to believe him but I know him personally too, and that helps. He has been around knives about the same amount of time as I have and we have both ended up pretty close in choices of user steels and platforms to cut with. Some differences though. I like tool steels more and he does more work with true super steels. He has worked with some of the bigger names in the business on this project too but they have chosen to remain more behind the scenes in supportive roles.
Any how that's how I see it. Jim will correct any discrepancies I have here hopefully.
Thanks,
Joe
But in the end alloy content will still be king in this type of testing.
Thanks Jim.
As much cutting as you do it would have to be a factor. At some point, all else being equal, those hard vanadium and tungsten carbides will do exactly what they are there to do.
Joe
Thanks,
Joe
The analogy that always pops into my mind is cement/concrete. Aggregate is a good thing, to a point. Too much or too little doesn't work very well.
Yep, the type of carbides will make the difference like in the M390 vs S90V shootout with the coarse edge, S90V won out due to the high percentage of Vanadium Carbides, 9% vs 4% for M390.
I know that chromium carbides are not as hard as vanadium ones. I was just curious if anyone knows what percent of the chromium is tied up in carbides in S90V and in M390 for the above shootout? I know Bohler's website states that 12% of M390's chromium is still free for corrosion resistance. But does that mean a full 8% is left to make carbides?
Is CTS20CP the same as CTS204P in performance?
Jim, I've lost track of which of the tested knives were Military variants - do you have a sense of how the various variants stack up against each other (S30V, XHP, M4, M390, S90V, etc.)?
