Yesedge retention is really a Q for today industry?
Why give up anything? Have both toughness and easy to sharpen.when high edge retention comes from trading off toughness and esay to sharpening ,what do you think?
Yes. If you disagree, come up with you own test.this test is really a good one ?
You get what you pay for.10 bucks ontaio butcher knife is useless?
Yes
Chuck
i do not wanna do the edge retention test by myself , the reason is very simple , there is no need to do it.
as i mentioned above that some plain cheaper ones can meet my needs , and i get huge satisfied with those things.
BUCK for folders and hunters
cold steel 1055 for big choppers
scrap yard for big knives.
i can get what i want & i can choose right tools , so i make few Q above , inquiring what is the necessity for those labor consuming test and gets nothing.
thousand years , mankind have been use carbon steels , those simple steels works and works well , many generations lacking of seeing OP's retention test , they lives and they lives well , so what is the necessity to do edge retention test like op ?
i can not get the right expression on it in english , 吃饱了撑的!
by nelecting some metrics ,like lateral strengh and toughness of the steels , just do cuttings like OP and get conclustions , no significance!
high alloy and high HRC is cool , this is what i get from the op's test .
i do not wanna fuss any one here , just say some things what i thought.
thousand years ... so what is the necessity to do edge retention test like op ?
Hardness and toughness may be considered “step” or “threshold” functions; that is, as long as the property is high enough to prevent damage (indentation or breakage), there is no further advantage to increasing the property even higher. However, wear resistance may be considered a “continuous” function; that is, continual increases in the wear resistance of the steel will result in increases in the life of the tool. Thus, upgrading for wear resistance may always offer benefits, provided other properties are not compromised.
Dingy, I wish we all knew how to type Chinese.
Your assessment of the test is correct about "high alloy and high HRC" - the high HRC gives edge strength against compression or rolling, the high alloy gives abrasion-resistant carbides.
In the thousands of years of blade edge technology, man has tested many materials - wood, stone, various metals heated & cooled various ways. Wood is very light and could be made very sharp, but it was not very strong when also very thin, nor does it resist abrasion - there are some materials that a wooden blade simply cannot cut. Stone blades might resist abrasion very well, but again could not be made very thin without becoming very fragile (not tough), and were heavy. Bronze and iron could be made thinner and lighter and tougher than stone and more abrasion resistant than wood but still not very strong unless heated to the point of brittleness. But by adding carbon and alloying elements, and heating/cooling in particular ways, we can achieve edges that are very thin and so cut very well, also very tough and strong compared to stone or wood so thin, and also very abrasion resistant! And there are other aspects, like corrosion resistance, that have been discovered / developed.
In truth, many of us have no need for such incredible technology. Many could get by with wood or glass or plastic blades. Many could get by with basic steel. But for others, the new technology is of great advantage, just as steel was an advantage over bronze or wood for weapons and tools millennia ago! But the advance in technology comes at a price, just as steel was more expensive than wood. YOU must decide if the advantage is worth the price. Do you cut a lot of abrasive material? If not, this test is not important to you, high wear-resistance is not an advantage.
If what is important to you is lateral strength and toughness, it is already known that steel "strength" increases linearly with hardness (so long as the steel is free of occlusions and micro-fractures), and toughness increases as carbide (including iron-carbide) size and segregation decrease. Heat treatment can dramatically alter the steel matrix of low-alloy steels: http://www.bladeforums.com/forums/s...de-testing-results-summary-and-lessons-learnt
Testing the same steel from different makers, even at the same hardness depending on how it was achieved, may have dramatically different results in impact toughness in terms of the damage sustained.
But I think Crucible provides a better summation as to what this test is about:
http://www.crucibleservice.com/eselector/general/generalpart1.html
So how tough do you need your knife to be? How strong? And will you sacrifice cutting ability (geometry) or wear-resistance (alloy content) to achieve that?
To those interested in the impact tests, what sort of stress-tests do you envision to emulate reality and so demonstrate the steel's ability to endure? What will be the baseline?
I'd be very interested in this info. It wouldn't give the exact strength of a particular knife but you could get some sort of a baseline for different steels.
