- Dec 4, 2005
Nice work mountainman, the Rat 7 looks great :thumbup:
I think I'll try it on my Rat 3. Exactly which paint remover did you buy at Home Depot? Also, did you need a real tough brush to remove the coating?
Thanks in advance for the help.
Thanks! I think it looks a lot better now, too. The coating was getting pretty ragged from all the chopping I do, and really wasn't serving any good purpose. The only concern that I have is what will happen to the handle portion, since it doesn't have the same surface finish as the blade. When I took the slabs off to strip it, there was some rust in one of the holes. I'll keep an eye on it, and post the results in a future "RAT7 vs. ______" thread.
The stripper is indeed the one in the picture. I put it there for reference, should anyone want to duplicate my project. I don't know that it's the best for the job -- as I said, Home Depot's help isn't much help -- but it worked fine for me.
The brush was a fairly stiff plastic model they had next to the paint strippers, and is one intended for use in stripping paint.
Should you want to strip your knife, I highly recommend getting some thick latex gloves ahead of time, putting down some floor protection, and making sure you're in a well-ventilated area. I used automotive repair type gloves, which worked well, but still got a bit of the remover on my arm. It really burned, so I'd take their warnings pretty seriously.
The directions say to apply the remover and let it sit for 15 minutes, but I was too impatient so I poured it on (it's like really thin jelly), moved it around with the brush so it covered the whole blade, then started brushing away. It dries pretty fast, so you'll have to pour some more on, but it's really a pretty easy process.
After the majority of the coating came off, I quit brushing and started sanding. A few minutes of this gets you a nice, shiny blade, which I enjoy looking at much more. Like I said before, just stay away from the edge, or you'll be doing some serious resharpening!
