- Jun 9, 2005
The RD7 is an awesome blade compared to a Rat7 or BK7. it will take alot more abuse & still be in one piece & Justin will customize one for you for very little extra! his knives are built to last!
What's the thickness on a RD7??? .25???
I have been looking at the Rat-7 and the Tops pasayten. Will either of these handle the moisture of the Oregon coast where I live?
Mack
Beware the Candiru
The TOPS Pasayten I own is significantly thinner (and shorter) than the Rat-7. Good cutter, but not a substitute for the two knives he asked about, much less a beast like the RD-7 (7" not counting the 1" choil).
The coating on the Rat-7 does nothing to protect the most important and vulnerable area -- the final bevel.
The RAT is coated, so the moist climate shouldn't be an issue. If you're going to be using the knife hard, which might remove some of the coating, keep it wiped down with Tuf-Cloth. Or get it re-coated.
The Pasayten is made out of a really good stainless. Obviously a very different experience, but if your climate necessitates it, there you go.
If you're not going to be using the knife real hard, I'd look at the RAT.
If you are, I'd look at the TOPS. 154CM is one of the best stainless steels around and will save you a LOT of maintenance.
