- Jun 25, 2017
X
The majority of us hobbyists will never over-stress a handle enough to have to beg for the very best. As long as there is no runout and no knots most of us could get away with Poplar or Willow. Cherry is soft (Apple is not!) and has an amazing amount of flex and I don't see this as being a liability on a short handled (or hatchet length) axe.If its prunus avium (cherry), i would only recommend it for hatchets. It's about the Same as Wood from an Apple tree. It's slightly weaker then birch. So with the bilnass it could Be tricky, because of the length and the headweight.
as for drying it: Best to clamp it or to hang it with a weight on the end. Fitting the Head loosely on it should do the trick. That way It's less likely to warp!
I've been wondering about crab apple lately as it is the only hard wood that I can think of that grows local around here. Would be interested in seeing what you think about it when your doneI agree ,got a crab apple I have been whittling on heart wood is pretty tough
I wouldn't be to sure about that? You know headweight of that bilnass is rougly 3 pounds right? (actually a little over in most cases) Apple is to brittle (bendability is ok, but not great although it's a bit stronger then birch) and cherry has a lower mass (although bendability is great). I have it growing locally and could get as much as I want as well as plum, pear and chestnut trees. Very nice texture, but going over 1kg /2lb is going to give problems and going over a length of say 50cm/20" has the same effect. Although with the latter I must say I prefer slim handles. The only club I have is the one on the skeggox, and that still needs rehandling.
So if you leave it thick enough it could probably survive. And as long as you don't mind the time and its free wood its allright!
I've checked for Oregon and the list of trees with the usable wood is:
Maple
Birch (european birch is a bit stronger, but as long as the grain is good it doens't really matter)
Hawthorn (used for clubs in Ireland, so should be allright)
Ash (european ash is a bt stronger, but it should be allright even as you slim it down)
Holly (it's heavier then Black locust or hickory. Bendability is about the same als black locust. Maybe a little less) You can recognise it from the red berries an spiked leaves, so good luck with foraging it
Walnut
Tanoak
Sycamore
Plum (hatchet size)
Cherry (hatchet size)
Apple (hatchet size)
Pear (hatchet size)
Oak
Black Locust
Yew (european Yew is stronger, but its still very good. It's a pine tree with berries on them. Don't taste that, you will die! Dont lick the wood either: You will die! So dont get the sap close to your mouth via your hands )
Elm
I crossed referenced it with the latin names just to be sure you don't have some weird genus thats totally different!
On paper many species appear to be suitable for handles until you start seeking out a suitable diameter round that is straight and has no knots. That's when the selection process narrows considerably. I'd love to try making a pulpwood (boy's) axe handle out of Apple but in 20+ years of rummaging through orchards that are being cut down (to make way for housing) I have yet to find a 2 1/2 foot long piece of an upright trunk that is blemish free and straight (and also doesn't twist).I wouldn't be to sure about that? You know headweight of that bilnass is rougly 3 pounds right? (actually a little over in most cases) Apple is to brittle (bendability is ok, but not great although it's a bit stronger then birch) and cherry has a lower mass (although bendability is great). I have it growing locally and could get as much as I want as well as plum, pear and chestnut trees. Very nice texture, but going over 1kg /2lb is going to give problems and going over a length of say 50cm/20" has the same effect. Although with the latter I must say I prefer slim handles. The only club I have is the one on the skeggox, and that still needs rehandling.
Maple
Walnut
Tanoak
Sycamore
Plum (hatchet size)
Pear (hatchet size)
Oak
Black Locust
Elm
Cherry Flavored Kemi 3 by Agent Hierarchy, on Flickr
Cherry Flavored Kemi 3 by Agent Hierarchy, on FlickrKevin, thanks for the suitable tree woods list. I need to look for Elm I recently saw Holly being used for a nice handle on Dubois’ site – Finnish hatchet actually. We have it around ornamentally and wild but you are certainly right on it being a prickly thing to process.
The head is 2lbs 7+oz and the handle is 23” before fitting. I am going to make it as slim as I can. No question on my part about the wood. Makes for a fun project.
Let it play through - you won't be sorry - this song is running through my head as I work on this thing lol.
I do have some help as well. “Followed me home” 2wks ago. He’s deaf. Likes the shopvac. Not very sage advice though.
Perhaps if you don't burn wood in the stove to heat the house! 'Soft' Maple (Silver, Red, Mountain and Manitoba (Box elder)) are worth nothing around here whereas Sugar Maple ('hard' maple or 'rock' maple) is king. Quite a difference between them and you won't find a baseball bat manufacturer or custom furniture maker accepting any other. They look quite similar until you actually heft a piece! That has to translate into something if you're not in the market for Balsa wood.Weight has a lot to do with the amount of moisture in the wood. Once it dries out, it'll be roughly 650KG/m3 range. Slightly below the 700KG of european ash, and about the same as your local Amercian Ash. The type of Ulmus other then isn't that important, other then the looks of it. I haven't found any difference?
