I dunno. I think putting compound on Kangaroo leather is like putting A1 sauce on a Lawry's prime rib.
I look at it as 'being so proud of winning a Gold Medal, that you have it bronzed...'
Stitchawl
Well for starters I never said that Roo Leather contains more silicates than bovine or equine , although this is kind of a moot point as I am about to discuss.
A) Ken does not split his Kangaroo Leather. I just confirmed that over the phone this morning.
B) The silicates in any leather have very little if any abrasive effect whatsoever the bare Roo leather strop at the top of this thread has been used quite a bit , and yet I see hardly any metal deposit at all.
The silicates tend to cause more of a burnishing effect , which is a totally different topic , if your interested in that then I would suggest doing some reading over at wicked edge forums , Clay has done some interesting testing regarding the subject.
C) The reason that you want a leather with fine silicates is that you don't want the silicates interfering with whatever compound you choose to use that strop for
HH and I briefly discussed this earlier in the thread. And he was right on the money. You want a leather with fine pores so it does a better job of presenting abrasive instead of hiding it.
Again , what makes kangaroo leather the best for stropping is the fact that its the thinnest leather , with the smallest silicates.
Hi Stitchawl,
That's a lot of interesting information and I agree with the majority of what you are saying, especially the processing techniques employed (Russian leather techniques, etc). That doe skin does sound interesting. I guess the point of the discussion I find missing is comparing silicates in terms of Mohs hardness compared to CBN or other abrasive compounds. There is some abrasive content to the Kangaroo, not a lot, but more than the nanocloth. So the difference is that you are referring to processes that supposedly increase the surface concentration of these fine silicates. I will accept that as your expertise. So using the approach, you are entirely relying on these silicates for abrasion. It isn't an unreasonable approach. But there are other approaches.
So with Kangaroo, you can use it without compound for good effect. BUT, and I would suggest you try it, here when using compounds we are not relying on these silicates. Indeed if there were NO silicates, it would be even better. This is the case with nanocloth. We are using the applied abrasives instead, wanting as close to a neutral substrate as possible. They cut far faster.
So, for instance using compounds finer or as fine as a tenth micron I would recommend you compare your edges off of say a Russian leather to a Kangaroo strop with a tenth micron CBN or 0.025 micron Polycrystalline diamond treated strop to them.
Well the topic has reached an impass. Clearly if my point was to sell you, I would have failed. It isn't. It is simply to correct what I perceive as misconceptions and some circular reasoning to support an entrenched point of view without sufficient data. I do find your describing me as a seller of Emperor's clothes, magic elixers etc not a very convincing way of winning points in a discussion, bordering on an ad hominem argument rather than a logical one.
"...diamonds are harder than silicates, but silicates are harder than steel. THAT is all that matters. For a 'final strop,' I completely rely on the natural silicates found in the leather. They are more than enough to finish an edge...."
It really isn't all that matters. If it was we would all be using silicates as abrasives for everything. There are several forms of aluminum oxide, silicon carbide and other abrasives like CBN Boron Carbide and various forms of diamond, to say nothing of a variety of natural stones. They are used to achieve various results.
" How much faster do I need? Save 4 seconds but spend $75 to do so?" How about zero seconds? I would argue that having achieved an edge that IMO I find superior to a finish stopping at a Russian leather strop is degrading the edge I can achieve. It is going backwards for me. Here we may simply agree to disagree.
I have tried both and this is the data I have to support my argument. If you have actually tried both approaches AT THE LEVEL OF PARTICLE SIZE being discussed, then we have a difference in interpretation. If not then you have insufficient data to support your conclusions, hence my assertion that you are supporting an entrenched point of view with insufficient data.
"For someone who wants to use a strop like a stone, and spend 30 minutes to an hour stropping, rather than working the edge on stones ..." If you are implying this is my approach, you are quite inaccurate.
If there are so many silicates in leather , why do you need to "bring them to the top"?
I have yet to see any evidence that this preparation moves silicates through the leather to the working portion of the strop. Its just illogical , how can you pull something through leather like that. It would be like trying to pull a grain of sand through to the top of a blanket using a rolling pin....
I can agree that creating a denser leather is beneficial , less convexing etc. But why would I invest my time to do that , when I work 80+ hours a week , when I can just use kangaroo leather which is already thinner and finer than the prepared Russian leather?
Additionally , do you have any references in regards to the actual size and/or particle size distribution of the natural silicates found in leather?
This thread is waay off course from the OP's initial statement.
I doubt I will convince you of a thing - let alone a sale. But letting inaccurate statements (Opinions, not facts] of either me or my products go unchallenged is something deserving a response
"I'm not implying anything. I'm stating a fact. And I'll re-state it. "For someone who wants to use a strop like a stone, and spend 30 minutes to an hour stropping, rather than working the edge on stones, the Polycrystalline diamond compounds are certainly faster than other compounds." Or are you now suggesting that Polycrystalline diamond compounds are NOT faster than other compounds? "
Again, read more carefully. I am saying that that is not my approach.
"I was ridiculing the outrageous cost and claims of an un-needed product." To be clear, this is your Opinion. It differs from mine, but it hardly rises to the level of being a fact.
Cost seems to be a major issue with you.
I see Russian leather strops in excess of $100 on the net too. Should we only consider what YOU feel is an appropriate amount to spend on these strops?
Well let me clear up a few misconceptions. I do sell nanocloth, Kangaroo leather and a bunch of other things too, including other leather and other stropping media.
As you sell / trade leather products, I would consider your responses as educational as my posts. Please don't impugn my motives as you hardly know me at all.
When it comes to just finishing an edge, your Opinion is one of many, as is mine. Some feel quite content with a 8k edge (not me), Some with various European stones (Eschers, coticules, etc), and some insist that only a Japanese natural stone like a Nakayama Asagi or Kiita or Iromono will do. Some of these stones FAR exceed the cost of a strop, yet perhaps this is a bone of contention on your part as well?
Regarding the use of compound. On the strops we are discussing here - 1x6" in size a SINGLE DROP is enough to coat them. This one drop will last for MANY honing / sharpening sessions. I can easily get well over 50 honings on a single application. At this rate one bottle will last me YEARS for final finishing applications on a bench strop.
If you wish to save even more money,
You do know that paper contains silicates as well. In fact both the plant material in paper and to an extent, the silicates brought in by the water used in paper production contain silicates too.
This material is pressed and rolled too, with various hardnesses and finishes. Should we say that using Russian technique treated leather is 'ridiculous' and an unneeded product, ridiculously expensive compared to copy paper or the newspaper used for years in Japan for final finishing?
"I guess you didn't bother to read the line I wrote that said; "...But me, as a knowledgeable consumer who has already used polycrystalline diamond compounds knows, ...." Sometimes it pays to read before you respond."
Sometimes it pays to read what I wrote more carefully too. I even capitalized it to help. "AT THE LEVEL OF PARTICLE SIZE being discussed," If you have tried particles sizes below tenth micron, then please accept my apologies. Otherwise please read more carefully.
While poly does cut faster than other abrasives, depending on the steel etc., that isn't what I was discussing. What I was discussing is that stones are not going finer than 30,000 grit and most finish using stones at 8 - 15k. So to suggest that a weaker abrasive present in 'Russian' Leather' that is up at 1.5 million grit is an optimum jump from even a 15 k stone is a HUNDRED FOLD jump in grit size! Suggesting that this is OPTIMAL should be something to ridicule,
I certainly would like to see a well referenced source for this data regarding leather silicate sizes, as I was unable to find this. Please read this a bit more carefully - I said well referenced, not hearsay. I also would like a reference describing how the Russian leather treatment brings these silicates to the surface - again not hearsay.
"You are selling products that work. You are selling products that are expensive. You are selling products that solve a problem.
But... there are other ways to solve the problem that are FAR less expensive and work just as well for most people. To suggest otherwise is doing a disservice to the buying public."
Again this is opinion not fact. You are entitled to your opinions.
It is your Opinion that your approach works just as well - one I disagree with.
You really have not laid out a convincing argument yet.
So your argument is to follow these 'typical' users edges with a surface of 1.5 million grit or so instead?
It should be obvious to you that not all applications would benefit from 25 nanometer (not 20 as you state) levels of finish - or a Russian leather strop either.
Yes, the kangaroo leather strops sold by Ken do dent when a fingernail is pressed into them. The leather is very soft.![]()
Did you get bad result when strop on bare roo leather?
