- Feb 28, 2002
If people were commonly attacked by wild cinder blocks while stranded in the wilderness, hammering a knife through one to test its ability to withstand that stress would be relevant.
Point taken.
I guess my real goal was to concede that in some survival situations one will probably find themselves using various devices or material in a manner it was not "intended" for.
I know intuitively that if I drain all the oil out of my truck and jump on the interstate, running at 70 MPH, it is abuse. It will fail. What difference does it make if it fails in 3 minutes or 10 minutes?
I have never done this, so how do I know it will fail? How do I know it is abusive? Common sense, or intuition.
Sure, you might. You might have to abuse the knife; you might have no choice. But there's also a question of what's likely, in context. Let's take the issue of batoning, for example. If you're in a situation where you might need to abuse your knife in order to make firewood, and you happen to have the knife in that situation in the first place, why would you not also have a small hatchet, if it's likely to come up at all?
So why are you asking if a hatchet would be on hand?
So again, it's perfectly reasonable for any given user to reject that aspect of criticism, but it is not reasonable for him to argue that simply because he rejects it, it's not valid.
Here's that example again. What you're saying is true, but not valid.
A valid example would be more along the lines of testing two trucks to see how much damage was sustained from running say, 100 miles with the oil volume at 50%.
It's not valid because it is not logical. Rejecting it is a symptom, not a cause.
I personally don't buy my trucks based on how well they will perform when subjected to conditions that I willingly know in advance are abusive to them.
I choose to disagree. It is valid. Any internal combustion engine is built to run at capacity, with a margin of error for consumption, leakage, etc. If you PURPOSELY drain out 50% of the oil, you are knowingly abusing the truck's engine beyond what the manufacturer states is normal operating conditions.
A lot of what might be considered abuse occurs in situations that are not "known in advance".
Abuse should never be the standard by which we evaluate the "success" or "failure" of a tool.
There may be cases where it is necessary to abuse a knife. Abuse should never be the standard by which we evaluate the "success" or "failure" of a tool.
Except of course in cases where the tool in question is designed and marketed partly around the idea of being able to withstand abuse - and to groups of people who will undoubtedly find themselves in emergency situations where solutions will have to be improvised.
Then how do you know you'll even have the knife with you?
But to what level of abuse to you set the standard?
But to what level of abuse to you set the standard? Hammering thru cinderblocks? Being attacked by a gang of car hoods?
