- Feb 7, 2000
I do continue to carry a Gerber Armbar because when I did need a multitool, it was mostly for a screwdriver. The Armbar carries easier and takes up less room. I do wish they'd come up with a pocket clip for it![]()
Well the Jetsetter isn't a " SAK " because it has no blade, but here you go.Love to see your slip joint pliers and SAK setup sir! I recently reignited my slip joint plier flame. I tried veeeery briefly to carry a Rebar in a belt sheath a while back and it was overkill for me to say the least. I have an old Classic without the plastics scales on my keychain and just picked up a few old Leatherman Micras that I cleaned up and throw in pocket sometimes. Knife used majority of the time but on occasion it’s nice to have a little something that can scrape, screw, poke, file, etc.
What part did you most break, out of curiosity?I gave up on Leathermans, broke a bunch and they eat up a lot of real estate in the pocket. They're fine tools, but I tend to be a bit hard on anything I carry all the time. 5 inch knipex cobras and a swisschamp are my current go to.
The pliers on every one of them. Admittedly it was usually doing something stupid, so out of principal I didn't send them in for warranty work (I sent a juice s2 in once and they're great to deal with). It's easier for me to eat the cost of a new pair of pliers than an entire multi tool.What part did you most break, out of curiosity?
You can't use the pliers at the same time as the screwdriver(s)/bit holder.
And that is why I have no interest in a leatherman with a bit driver or in adding an attachment to my leatherman.That’s actually a good point. With a multitool you can’t, for instance, use the pliers to hold a nut on a bolt while also using the bit driver to unscrew the bolt.
I have one and the only thing I like about the carrying case is the sturdy key ring clasp that it comes with. I took that off and immediately repurposed it.I'd never carry the whole thing here, but this GM power torque version of the ubiquitous HI-FIVE bit ratchet does come in a relatively compact pocketable little case.
The M3 is the best one but they don't go up for sale very often. I've given up on getting one. I'm happy just modifying the Style PS by replacing the scissors with a knife from the Style CS. It's almost like a mini Skeletool.Today I have decided to go back to this Sebertool M4 over the 4" slipjoint pliers which don't carry as well for me in the summer.
I modified mine and it no longer has a knife, but these are such a great tool and they really blow the leatherman squirt out of the water in my opinion.
Consider the word goozler officially stolen by yours truly.A full sized pair of farmer pliers or knipex compact water pump style pliers (both have belt sheaths) along with an SAK actually fill my needs better than the Gerber multiplier I mentioned earlier in this thread. I was happy to have the big pliers on my belt last Wednesday when it was time to remove a treble hook from a 3 LB bass' goozler.
If I still had mine I'd send it to you, but I gave it to my buddy a couple years ago.The M3 is the best one but they don't go up for sale very often. I've given up on getting one.
Are you talking about a universal joint swivel socket, or a knockoff of the Gator grip socket ?I used the 4-13mm size socket that comes with the 4 piece tacklife kit.
The knockoff gator grip. The concept of the gator grip was always good but in the real world it will fail with high enough torque. The good news is that you're not likely to cause the socket to fail when using it with such a tiny ratchet.Are you talking about a universal joint swivel socket, or a knockoff of the Gator grip socket ?
The US made gator grip seems to be the best one, but I wouldn't put much torque on mine.The knockoff gator grip. The concept of the gator grip was always good but in the real world it will fail with high enough torque. The good news is that you're not likely to cause the socket to fail when using it with such a tiny ratchet.
