ea42
- Jan 1, 2006
I followed this method and it worked flawlessly. I will warn you, you will be tempted to hit the blade a little harder after a few taps. It will seem like the little taps are not working. Then, like magic, the blade will start to center for you. Do not rush the process, especially on that knife.
I would even try it on a cheaper knife. Work it off center and then back to center. That will give you an idea of how light to tap the blade.
You run a very strong risk of snapping the blade tip off doing it this way, especially on better knives with higher hardness ratings. The blade should be supported somewhere around its midpoint.
