When I cut cardboard I typically use a box cutter. It works well and I can't really complain. But I am thinking of also buying a fixed blade to use occasionally when I'm in the mood to cut cardboard in style.
The question is: which one is the best suited as a cardboard cutter? I am thinking it should have the following characteristics:
1. Narrow blade. Width is a negative here.
2. Supersteel level edge retention, but also decently rust resistant. M390 or S110v? S110v might be too chippy? Other recommendations? Is magnacut a good choice here? It's edge retention isn't that special.
3. Blade shape: should be mostly flat as lots of belly is a disadvantage. Wharncliff might be ideal but isn't required. And the blade should be short-ish. A long blade would be counterproductive.
4. Decent size handle for comfortable cutting
Thoughts? Does anything like this exist? I'm open to a custom knife maker if they would be into making such a thing.
