The scales are held away from the blade by the blade pivot bushing. If the pivot rivet is not squeezing the scales against the bushing, there can be some side play. Squeeze the scales in a vise to see if the side play disappears. If squeezing tightens the pivot, you need to peen the pivot rivet while supporting the opposite end of it. Alternatively, you can disassemble the pivot, remove some material from the bushing, and reassemble using a screw set. The bushing should be a couple of 1/1000ths of an inch thicker than the blade.After a lot of WD-40, Q-tips, soap, water and some elbow grease, this is how it looks now.
Someone clearly changed the rivets before (or atleast tried to) and left plenty visible marks on both sides.
Also there is some blade play. Tiny bit up and down, aswell as left and right. Is there a way to fix this without putting new rivets/screws?
The blade seems to be in good condition luckily. Still with a nice tip.
Does anyone know from what year this knife is?
