- Oct 30, 2005
I just don't think there is any plausible way for the Vic side lock to disengage by accident.
I like the old Vic side lock, but I don't think it is a particularly strong lock.
"Now if only CS would offer something more conventional in appearance with G10 and nicer steels "
The American Lawman looks nice and fits your criteria. G-10, steel liners, Demko's beast lock and AUS 8a (never had problem with CS's AUS 8a)think they can be had for around $65 online.
I also love the play in the lock, it WILL without a doubt tell you that you're using the knife in such a way that the lock is holding the knife open.
And just what is the proper tool for stabbing into something to start a cut?
I've done such with slipjoints without any particular issues. Why should a locking knife present any special issues?
"NEVER trust a lock"? Why not? The whole point of having a locking knife is to have a blade that locks open. Locking blades are also a safety feature to prevent the blade from closing on ones fingers. Safety features are expected to be 100% reliable.
Nothing is 100% reliable. Having a 'safety' on a dangerous device does not relieve one of using proper (and safe) practices with that device. Would you put a loaded .45 pistol to your head, and pull the trigger, just because the "safety' was on?
If so, there's no more use in talking.
If not, then you get my point.
Locks and safeties may usually work, but I wouldn't trust my life, nor my fingers, to them.
Of course, one can stab (carefully) into an object to start a cut, but the emphasis here is on "carefully"...so that the pressure of the stab is toward the cutting edge, not the spine. As you rightly said, this can be done safely with slipjoints...as long as you think about what you're doing before you do it.
Use your head, not the lock.![]()
If one uses every knife as if it were a slipjoint then lock strength is irrelevant. It's only when you goof up that the lock becomes an issue.
I love to debate lock strength as much as anyone, but the simple fact is that if you're doing a task that might stress the lock enough to fail then you should probably be doing it with a fixed blade. The only exception to this I can imagine are things like self-defense, survival or farming where it's not practical to carry a fixed blade or go get one before continuing.
Now we're getting somewhere. It seems the Axis Lock is the best effort so far. Cold Steel's Ultra Lock appears to operate in a similar manner on my Recon 1
