Cliff Stamp said:Burrs form by a number of methods, the most common seen when honing is a deformation burr where the edge folds over because the pressure on the edge is too high and the cutting aggression too low - thus it deforms rather than be cut. Therefore you would predict for example that a loaded stone would be far more likely to induce a deformation burr than a clean one - which is indeed the case....
-Cliff
daberti said:So, if I got it right. ...
Should I be able to get a evenly lighted edge, the burr would not be present.
How would you compare it to S90V (thoughness and edge holding).
How would you compare S90V and ZDP189 as far as corrosion resistance, toughness, wear resistance and edge holding are concerned?
Cliff Stamp said:These are two very similar steels, both are P/M, high wear, high carbide stainless. Spyderco has CATRA data which show these to be similar for long term blunting which is reasonable based on what I have seen comparing ZDP-189 to S30V. I would be interested in a detailed comparison of them because it would make some interesting points about edge stability I am curious about because the smaller vanadium carbides should be more stable than the larger fraction of chromium carbides in ZDP-189. S90V would also be expected to be tougher due to the smaller carbide fraction but again neither of these are tough and would respond well to impacts or bending. S90V has also recieved some complaints about sharpening due to the high vanadium content, not responding well to a sharpmaker for example at very high finishes.
-Cliff
daberti said:My understanding is that edge retention would be the same under normal circumstances, but S90V would be quite superior when cutting abrasive media.
S90V toughness should be superior and corrosion resistance too, as ZDP is less corr. resistant than even ATS-34
Cliff Stamp said:Continuous salt spray was used for quite awhile to attempt to predict enviromental corrosion resistance. However it didn't correlate well, the data was very precise but not accurate. So interrupted salt sprays were used which were less precise ubt more accurate. Eventually someone built a machine which did this cyclying, the q-fog. It can do fog, dry, or high humidty and cycle to simulate a natural enviroment.
This is just the same thing as hanging the blades on a clothesline. The q-fog machine just reduces the variance and thus allows a much more consistent result with a much smaller sample time. This is a common approach in research, if you throw a lot of money at a problem you can get an answer in a much shorter period of time.
-Cliff
Cliff Stamp said:Yes, pretty much everything looks soft compared to diamond. The only real issue I have found is that there is a bit of a static electricity burr issue, some water helps.
-Cliff
Cliff Stamp said:After sharpening on dry diamond plates, when I check the edge under magnification there is debris stuck to the edge by a static attraction. I generally use plain leather and a few trailing passes to remove the worst of it.
-Cliff
daberti said:I saw it too!! I thought I was drunk, but I was not. Did it happen to you only with S90V as I experienced?
PerformanceFirst said:I can't get a burr to form on S30V (knife is a Native) using a Lansky coarse stone. I tried for about 30 minutes last night but I don't think it was there. I checked both visually and by dragging my fingers across the edge. Can someone tell me what I'm looking for? I'm beginning to think I need a diamond stone. Or am I forming the burr and just not noticing?
daberti said:Strange: I didn't use anything but the weight of DMT stone itself.
