- Oct 28, 2005
i am sure spyderco will take care of it. if they offer to replace the knife, might i suggest a combo edge. with the length of the endura blade you get the best of both worlds in my opinion.
jtallant said:Again i refer you to my previous post #6.
jtallant said:Agian, it is an Endura 4 with the said steel liners, no I did not adjust the pivot screw, no it doesn't seem overly loose. And by slight pressure, I mean about 5lb. of force. maybe less. I tried getting a video, but doesn't show anything. You really have to see/feel it in person as the movement is too slight to view in video format, but considerably noticeable in sight/hand.
This is a real bummer. Those are great pics and nothing looks wrong with the edge. My guess is there is a temper defect.
Spyderco is like all companies and will have a lemon get out once in a while. What makes Spyderco better than most other companies is that they will make it right and you will be happy.
As an aside, nylon rope is one of the hardest materials to cut with a PE blade. If you are going to be a lot of cutting of nylon rope, you should look into a SE as it will cut well even when dull.
requesting a Foilage Green handle Endura with combo edge. Then, eventually get a ZDP plain edge to have both if needed.
Really? Why is that?sounds like a possible heat treat problem, but that really doesn't happen with production knives.
You must not have seen the post where the OP (Original Poster) stated he had contacted Spyderco and that they were going to "make it right."I would email or call spyderco and they will make it right.
Let me know if you want to try one with teeth in our replacement.
good choice. if you do end up getting the zdp may i now suggest to send it in to tom krein and have him grind it down. the pics posted here (or spyderco forum, i forget) were gorgeous and i like the flat grind better. mine will be done sometime after the knife show. :thumbup:
