RTAK ii 1075 now?
You are correct SK-5 is very similar to 1080. Carbon (SK-5 0.8-0.9%, 1080 0.75-0.88%) and manganese content (SK-5 0.1-0.5%, 1080 0.6-0.9%) are very similar and SK-5 also has small amounts of nickel, chromium, copper and silicon. The performance of both steels should be pretty much identical but the 1080 with the higher manganese content would have a slightly slower critical cooling rate and therefore react better to heat treatment if the critical cooling rates are marginal. That said I believe the problem with the blade is as you surmised- that it is a heat treating, not a steel, problem.
Let me do a little research and I will get back to you.
Hi Dan, thanks for your detailed response.
Is the progression of brittleness between 1055 and 1095 linear, or is there a critical point when the properties suddenly become quite different?
Also, what is your opinion on 1055?
I have machetes in 1055 that are quite soft from one manufacturer, and other 1055 machetes from another manufacturer that rival the excellent 1075 blades made by imacasa.
Mr. pangaman- Lath martensite forms in steel at 0.6% carbon and below and plate martensite forms in steels having 1.0% carbon and above. In between a mixture of lath and plate forms with more plate and less lath as you approach 1.0% carbon. 0.6% carbon is about all the carbon that will dissolve in the matrix (which is dependent on a variety of factors) and excess carbon will form iron carbides (in a simple carbon steel). These carbides can cause brittleness in steel.
As steel is hardened (transformed to martensite) the martensite will grow and the higher the carbon content the larger the growth factor. In higher carbon steels this will commonly cause micro-cracks as the plates impinge on each other which will also increase brittleness in steel.
1055 will not "fully harden" the matrix and you may find the blades to be slightly malleable but the "softness" problem is probably due to poor heat treatment.
A great reference for anyone with questions about heat treating blades is Dr. Larrin Thomas' "Knife Engineering: Steel, Heat Treating, and Geometry". Dr. Thomas has bridged the gap between "metallurgy" and "blade metallurgy" something I have been trying to do throughout my career. His book on "The Story of Knife Steel: Innovators Behind Modern Damascus and Super Steels" is also very well researched and worth checking out.
Thanks Dan, will definitely check out Dr Larrin Thomas.
Hi Dan, what are thoughts on SK5 which I believe is roughly equivalent to 1080, and
I therefore imagine be pretty close to 1075 if properly heat treated?
I have a cold steel bushman that lost a finger nail sized chip out of the cutting edge, and was wondering if it was just a random QC issue relating to the heat treat. The steel seemed quite granular around the chip.
Thanks for the informative articles!
Some of the Cold Steel Bushman were/are made in China. That might explain a poor heat treat. Taiwanese SK-5 is great steel. They learned how to make quality steel from the Japanese. I'm wary of Chinese steel. I'm sure there are some good Chinese steel companies, but there are also a lot of bad ones. I personally own one Cold Steel Chinese manufactured knife, the Large Luzon. It's 8Cr13MoV stainless steel. It's my EDC. I'll say this, it holds an edge extremely well. It's still hair popping sharp after like 4 years of carrying it. I continue shaving hairs with it, and it never gets dull. My genuine Ka-Bar literally got dull, merely from shaving hairs! I wouldn't trust it for any type of moderate abuse, but that's not what the Large Luzon is made for. It's a pure self defense knife, and it fills that role better than any other folder I've seen. It's light, fast, and has a long handle for slashing or choking back. I love how on Cold Steel's website, it doesn't mention that it's made in China, yet it says China right on the blade! 😂
Dan, the Ontario RTAK II 125th Anniversary Edition is still for sale on Chicago Knife Works. The original RTAK II 125th Anniversary Edition was 5160 high carbon steel, and it came with a leather sheath. Chicago Knife Works doesn't list the steel type for the version they have for sale. They just say it is high carbon steel, and it comes with a ballistic nylon MOLLE sheath. Is the current RTAK II 125th Anniversary Edition made from 5160, or 1075HC? I asked Chicago Knife Works what the steel type was, but they don't know. I would prefer the 5160 version, unless you think the 1075HC version actually performs better.
Dan hasn't been on this site since Nov 2023 and I doubt he still works for Ontario after the sale.
The newest RTAK II 125th Anniversary Editions were made from 1075HC, so I answered my own question. I actually prefer 1075HC to 5160.
You sir are one in a million I think. Curious as to why you would prefer 1075 over 5160?
Combination of toughness and edge retention. It's also easy to sharpen. It depends on the knife too. The RTAK II is probably better in 5160. The SP10 Marine Raider Bowie is probably better in 1075HC. However, I'm mostly going off of Dan Maragni's article on why he moved most on OKC's blades to 1075HC. I'm not a metallurgist, but Dan knows what he's doing. I'm pretty sure 1075HC is also less expensive than 5160.
I have a Marine Raider in 1095, I can assure you it's better than 1075 and holds an edge longer. But 5160 would be even better.
Everybody knows why they went to 1075, it was a bad decision that helped lead to their downfall. I have major respect for Dan, I still have at least one blade in Carbon V, but he was toeing the company line when he posted that article.
And FYI they moved to 5160 for the RTAK because full flat grinds are weak and the 1095 blades were chipping when chopping.
The older 1095HC versions were rock solid. Quality control started slipping, which led to catastrophic failures of OKC's 1095HC blades. 1095HC is more difficult to properly heat treat than 1075HC. That's why Dan made the switch. 1095HC will certainly hold an edge longer. By the time I bought an SP10, only the 1075HC versions were available.
Had nothing to do with quality control, 1095 is not more difficult than 1075 to heat treat properly, and Dan's 5160 was superb but they dropped it in their quest to get cheaper and cheaper and not have to deal with warranty issues. Soft tangs and bendy blades to avoid having to warranty blades that had been obviously abused by youtubers. Most knife makers said that's knife abuse and refused to warranty blades destroyed by extreme youtuber abuse, Ontario tried to ameliorate this by steadily implementing measures to make the knives softer and less prone to breaking until they got to a point where their blades just bent and rolled over as opposed to failing completely, and thus the 1075 of today.
Sounds accurate
*Does a knowing nod of knowingness to pretend to know what is nodding about.*
1075 was better for bigger blades. But I love the 5160 ones more. What bendy things I put mine through...would make one cringe. Not the sharp blow by blow stuff most people do with it...well not that much...maybe...
