Fresh from Columbia River Knife and Tool id the Frame lock S-2
This has an integral lock where the handle actually bent to keep the blade locked in the open position.
The style is similar to the Apache and the finish all around is gray bead-blast. This is a very attractive knife in a flat gray sort of way.
The web site text:
4-7/8" closed. ATS-34 Stainless Steel drop point blade with bead blast finish. Titanium handles with lanyard hole. Titanium pocket/belt clip.
The handle actually has a section which flexes over to hold the blade in the open position. Moving that piece of the handle aside with your thumb releases the blade so you can easily close it. The handle material is Titanium for strength and weight considerations. This is a very well made and designed knife and a real value at this price."
It has a good feel- not too heavy for its size. The lock is very secure as the blade thickness matches that of the handle and so it shouldn't fail. There are torx nuts holding the simple construction togther including one in the thumb stud and so it is likely reversible.
It's slightly larger than a large Reeve Sebenza and the engineering is very similar. Of course there is a noticable difference in smoothness and the steel is different.
[This message has been edited by Dexter Ewing (edited 02 December 1998).]
The web site text:
