?'s about treating 1095 and 1084
OK, now I'm wondering if I'm wasting time and effort here! I'm pretty sure I'm not hurting anything (though it'd be nice to be VERY sure!) but I'm no longer sure I'm not wasting effort either...
Dan, actual “normalizing” that meets the classic industrial definition, need only be done once. This is due to the nature of the heating and what it is designed to do. A proper normalizing heat is done at a much higher heat than almost any other heat treatment (1600F-1800F), in order to put everything into solution so that on cooling you will have even conditions throughout. This will only “refine” grain in the sense that it will make recrystallize things to an even size throughout and my even mean a larger size, but at this point even size is more important than what that size is. Unequal grain size can become problematic in subsequent heat treatments.
Stock removal does not mess with things all that much and that steel is pretty much the same as it was from the mill, but forging has all those countless things to go wrong associated with it. Uneven grain sizes due to dynamic recrystallization, and drastically different cooling rates (ever notice how dark the spot between the hammer and the anvil is compared the rest of the blade), cycling in at who knows what temperature in order to accomplish the shaping. With all of this not only grain size be all over the map, but segregation could be as well. The banding that too many smiths are in awe of as a super thing is actually viewed as a terrible thing that every other tool making industry goes to great lengths to avoid, and for good reason. There is an easy fix for all of these things- one good normalizing heat.
But yes there are downsides to every heat, if you don’t have good control you could overshoot even the normalizing range and at worse possibly burn the steel or make things too coarse to fix in one heat. But within the normalizing range you still have to deal with oxidation, decarburization and the like. So the least heats to accomplish your goal is most often the best. If you did everything right on the first full normalizing heat there should be no reason for a second or a third. Now move onto the next heats in the cycle.
That first high heat sets things up for the follow ups where you will grains and carbides, equalize any stress factors and eventually leave the steel ready for your bench finishing work. The next should be to just “critical” and then an air cool. It is here where you could throw in other heats to just critical and quench if you are concerned about grain size. The last heat is for final refinement and even for annealing purposes if you would like to avoid the overnight vermiculite thing, and if you threw a quench or two in before this the annealing and carbide refinement will be quite efficient.
Please don’t misread anything I say about grain size, it is important for overall matrix strength. Many smiths confuse grains and carbides, the key to taking an ultra-fine edge and holding it is much more reliant on carbide size than n grain size. If you have really fine grain size but huge blocky carbides edge forming, and even retention, will still be miserable, but the blade could bend just fine.
Hey Matt! I appreciate knowing that, more than I'm ablt to express, Thank you!
Yes, I've broken a few open, and the grain looks to be very even in size, but frankly, I don't have the experience with looking at grains to know exactly what I'm looking at. They could be just about perfect, or monstrous glom big, but without some perspective, I'd be hard pressed to know the difference by site.
Fractured grain size is about all most smiths have to go on, the actual measuring and sizing of austenite grains requires much more equipment and training than most of us have available and have my doubts that any smiths are actually doing it. But if you want a fairly reliable "control" to go from for fractured grain size assessment, get a good Nickelson file and break it. If your fractured ends look no coarser than this you are doing pretty good at controlling your grains.
But if you are don't get too cocky;), with all the mechanisms built into modern steel to control grain size, you really have to consistently overheat to grow grain. And even if you do it can be quickly fixed with proper normalizing. All the paranoia in bladesmithing over grain size really kind of tells one how out of control most of our temperatures really are. And the whole low temp forging phenomenon says quite a bit about this as well. When teaching a class, it only takes a couple of students to overheat steel the first day for me to spend a week constantly telling the class to get it hotter before hammering!
Mr. ern26, yes your questions are answered in the stickies, and yes they are some of the most common questions we answer here in the forums. But you have come here with specific questions about specific steels, AISI numbers and all, with a specific, well formulated quench oil in mind, and this demonstrates to me that you have a serious approach to the venture you are undertaking. This approach is the kind that inspires me to keep typing and answering questions and look forward to the blades you may produce one day.
Kevin, I hope you don't think I'm not serious about knifemaking simply because I went the canola oil route.:( I will be trying to get the Houghton Quench K for my 1095, but for now I gotta make due with what I have. There is also something I kinda like about using a natural oil though too and perhaps more primitive "tribal" ways. I may also give brine a try... Thank you for the most informative posts.:)
Hey Dan!
Great to see you back, I hope this means the things are going well for you! Looking forward to seeing your latest blades
-Page
I really don't understand, this is the first time you have participated in this thread that I know of:confused:. The O.P. didn't ask one of those all too general "how do I make a knife" type of questions, and although I have typed these answers more times than many people have lit a forge, the fact that he came here with specific questions, about specific materials I felt deserved my efforts to type it again. I was only giving him credit for the courtesy of providing the specific data to easily answer his question.
Sorry, Kevin. I probably took my emotions out of context...my mind's been pondering too much on that other thread I have going.:foot::o Sorry if it sounded like I was taking it out on you. I have an incredible amount of respect for you. I hear so much of this "canola's not a real quenchant, you need a real quenchant to make real knives." It is so discouraging to me as a beginner to hear that if I don't have everything just perfect or just so that my knives will be poor quality or inferior. There are so many variables, so many things to consider. As a beginner I am told that I should only buy the best belt grinder or the best anvil, or this specific quench oil. No matter which steel I choose, seems there is no way I can make a truly good knife unless I have a specially temperature controlled furnace to go with all the other stuff as well. It seems it never ends... I guess I'm just getting discouraged.
Now you've done it! We need more about this quenching between normalizing and the sub-critical anneal and how it relates to grain size and carbide refinement... or was that buried in the later pages of the quenching sticky?
...my mind's been pondering too much on that other thread I have going... I hear so much of this "canola's not a real quenchant, you need a real quenchant to make real knives." It is so discouraging to me as a beginner to hear that if I don't have everything just perfect or just so that my knives will be poor quality or inferior.
I totally hear you brother. It's enough to make you pack it all up at times. When I started, I was using O1, 1095, 5160, 52100 and the more I heard about the quirks of these steels the more dust they collected on the rack from lack of use. I was using canola oil and an LP Forge. I had to reassess what my goals were in knifemaking.
Kevin's 1% property tweaking comment really puts it into perspective. I swallowed my "Hot Ticket Steel" pride and stuck with what I was set up for... 1070/80 steels with simple heat treating proceedures. The performance of my blades does the talking for me, now. I have only recently switched to Houghton Quench K because I found a great deal at $75 CND. 5160 and 1095 are slowly creeping back into my menu... but without the proper equipment for consistant soak times, I'm still unable to use these great steels to their fullest potential. At this point, I have no urge to get into salt pots or digitally controled ovens... I'm having too much fun with low-tech!!
Just be honest in all aspects of your craft and folks will respect you.
Sorry for the thread wander.
Rick
I understand now. I read just the first page of that other thread thinking it was about 1095, but when I saw that it was going to be about the same tired and useless quenchant debate I read no further. I prefer reason and logic, and that thread doesn't interest me in the least, I don't care what anybody chooses to quench in, I have found what works for me, I suggest others do the same while allowing their peers to form wholly educated opinions. This thread was started by somebody who seemed to have all his ducks in a row with clear questions about what he wants to accomplish, helping in any way I could makes me feel good, while the quench thing makes me want to just avoid this forum. This thread is the way this forum used to be, I think I can speak for all concerned in requesting that those who want to continue the battle from the other thread should go there to do it.
Sounds good to me Kevin. It was not my intention to bring up any battle (I'm sick of the "wars" and battles too...they're not really helping me out), sorry if it seemed like that.:( I am actually so stressed about the whole debate this thing over that thing, this quench over that quench, this glue over that glue.:confused: I don't even know what to use anymore. I'm just going to stick with what works for me and try to learn from there. I have contemplated even leaving this forum because there seems so much negativity towards doing things in simple primitive way. I'm just going to make knives the best I can, test them, and try to enjoy this craft as much as I can. I'll try and not let it get to me so much.
Hope you understand, I'm only just trying to learn, but there is so much debate as far as methods or routes to take, it's hard for a beginner as myself to find any sense of direction.
P.S. Sorry I keep editing my posts. It's a bad habit of mine.:D
I personally find the most useful knife test to be in cutting things, that is after all what it is all about. Cut a wide range of things, cardboard, leather, wood etc… and see how the edge wears. A test with a brass rod that I like better than flexing is chopping! Take a good whack at a brass rod and see how the edge handles it. This will tell you a whole lot about your edge geometry as well as how much impact toughness your process is giving to the blades.
I hope this all helps.
I actually tried this test on my blades before. I figured that simply pushing the blade across the edge wasn't really telling me very much, so I just took a whack at the brass rod instead. Worked out pretty well.:thumbup: I was just thinking of another type of brass rod test to try out... What about taking the edge of the blade and trying to cut it almost like trying to saw through the brass rod and seeing how long it takes to dull? Maybe this would even work with mild steel rod to see how long I can "saw" with my knife edge before it dulls. I know it's really easy to tell a good hacksaw blade from a cheap one by how long it keeps cutting.:)
Try whittling the brass rod as if you are sharpening a pencil.:thumbup:
Good edge geometry will take you further than a couple extra HRC points ever would.
Rick
If I followed the heat treating "recipe" as close as possible and used a good professional oil, what other "variables" should I watch out for with 1095? That is the steel I would like to work with.
Yes much of it should be covered in the stickies. Heating a steel with more than .8% above “critical” and forcing it to air cool will make large carbide formations and even put them in paces you do not want them. Drilling this steel, even in the annealed state, will be miserable due to large carbide cluster. Heating to below critical, after a previous heat that put things into solution will keep the carbides very fine and dispersed, this will make for good abrasion resistance but not tear up your cutting tools. The quench cycle traps carbon in solution so that when you spheroidize the carbides formed are not big and lunky but very fine and evenly distributed. To do a full lamellar anneal on this would just put you back to square one for the big coarse stuff again, so the sub-critical is the way to go. It is all covered fully in the “hypereutetoid” section of the “Working the three steel types” stickie.
Sounds good to me Kevin. It was not my intention to bring up any battle (I'm sick of the "wars" and battles too...they're not really helping me out…
Amen! Turning everything into a playground contest displays a sad maturity level that I am just tired of dealing with. Too common in these exchanges are the sophomoric appeals to one on one contests, your quench against ours, your steel against ours, one of your blades against one of ours, “my dad can beat up your dad” :rolleyes: jeez are we going to meet behind the school at 3:30 or are people just going to grow up! The proof is in the performance? No it is not! If one guys blade out-cuts on rope or 2X4’s the other will ask for cinder blocks in favor of his edge geometry, and when one doesn’t come out on top in cutting, the other guys knife will be junk because it can’t easily bend in a vice. We can’t even agree on what a knife is supposed to do, how the heck can we be in lock step on how they should be made?
… I am actually so stressed about the whole debate this thing over that thing, this quench over that quench, this glue over that glue.:confused: I don't even know what to use anymore...
Use what ever works for you while fully recognizing exactly why and you will do alright. When you are first brutally honest with yourself then honesty with others just sort of falls into place.
I'm just going to stick with what works for me and try to learn from there. I have contemplated even leaving this forum because there seems so much negativity towards doing things in simple primitive way...
Funny, I have considered removing the address of this site from my computer for the exact opposite reason, whenever anybody tells you that you can have a deeper understanding of your craft by limiting your knowledge, the absurdity of the conversation should be self evident. I don’t think there is as much negativity over doing things in a primitive way, I know I myself really appreciate that style. I do believe there is plenty of justified negativity about not being honest about any approach. Spurning a hammer and driving nails with a rock does not make you a superior carpenter, it just means that you are willing to work twice as hard to drive a nail. On the other side of the coin, having a pneumatic air nailer doesn’t guarantee quality work, it will only allow you to put out tens times as much shoddy craftsmanship if you are not willing to take the time to learn proper carpentry. The idea that one is somehow a better bladesmith because they handicap themselves with primitive tools is every bit as abrasively haughty as feeling superior simply because of the sophistication of your equipment. Our brains are the only tools that really determine our level of craftsmanship, and a deep hunger for knowing everything you can about our materials and the process is the path to new levels.
I'm just going to make knives the best I can, test them, and try to enjoy this craft as much as I can. I'll try and not let it get to me so much. Hope you understand, I'm only just trying to learn, but there is so much debate as far as methods or routes to take, it's hard for a beginner as myself to find any sense of direction.
you go in the direction that your heart takes you in order to be happy, there is not much reason to make knives if it makes you unhappy to do so. Everything in life is a balancing act between following our heart for our own happiness and listening to our head about how far we can abandon our responsibilities in that pursuit. We owe it to ourselves to be happy, but we also owe it to others not to sabotage their pursuits with a failure to be honest with them, or ourselves, if we try to maintain bliss at any cost.
Rick
Geometry over HRC points goes both ways, they are both integral parts of the same package. Sharpness and cutting ability is indeed all in the edge geometry, but what geometry you can get away with is determined by the heat treatment. A poor heat treatment can be propped up with a heavier geometry, but aside from very heavy chopping the cutting ability will suffer. On the other hand finer geometries will cut like crazy but need to be supported by proper heat treatments in order to last. With simple iron/carbon steels (like the old stuff) the only tool you really had was HRC to fine tune the strength to hardness ratios, but alloying changed everything. If we can nail the heat treat we can have very high HRC along with surprising toughness.
To be honest, I don’t work with recipes, I work with tools that I can use in any way I need to accomplish my goals. A recipe would be something that we have to use because our lack of understanding of the process would not allow us to reproduce the same results twice without rigid step by step instructions to follow. Skilled chefs don’t follow recipes, they use their knowledge of what temperature and chemistry does to the food to write recipes for poor slobs who need to cook dinner for his three kids when his wife is gone (sorry Karen just has a short hospital stay that still has me in a tizzy ;)). But seriously, the ASM “Heat Treater’s Guide” is not a cook book of recipes, it is a toolbox with which one can take control of their own individual process.
Let’s just forget the oil and deal with the steel. 1095 has an overall lower Mn content making it more difficult to fully harden than say 1075 or 1084. This isn’t too much of a difference when once considers that 1084 may be .75 seconds from 1475F to 900F while 1095 may be .50 seconds, but a half a second is still pretty quick. Now I cannot emphasis this enough, because one of these days somebody is going to get hurt running for the quench tank, but this is from the time you begin quenching not from the time you pull it from the heat source. People please verify what I am saying with a magnet, heat a piece of steel to nonmagnetic and just allow it to air cool checking it as it goes and notice how blasted long it takes for the magnet to grab again, this is the Ar point, the point at which you have lost your window. For any steel you need to get into the quench as soon as possible, but 1095 cools no quicker in the air than any other steel. So please let’s lose this idea that the quench tank needs to be even closer to the forge for 1095, somebody is going to get hurt.
The timer on hardenability starts when the blade hits the quench, this is why the quenchant is so critical with 1095, as it has to be able to cool the given thickness to below 900F in less than .50 seconds. I don’t care what you choose, but choose well.
I cannot go into the same details that I covered in the “hypereutectoid” section of the “Working the Three Steel Types” sticky, but it is all covered pretty well there. Avoid very slow cooling from above critical with 1095, the old wood ash or vermiculate things is better for 1084 not 1095, and the leaving the forge over night should not even be considered with this steel. Sub critical or spheroidal annealing is best for this alloy, your mills drills and other tools will love you for it and the blade will come out with better properties.
If you are buying 1095 new on the market these days I would strongly suggest working it hot in the initial forging or practicing good normalization heats. If you could see all the micrographs I have of the segregations in this steel these days. In order to make samples for metallographic work I have to leave many fully hard and every piece that had a segregation stringer in the centerline eventually develops a crack in that line, this stuff needs to be broken up and moved around and heat is how you do it. I have been playing with 1095 for around 20 years and the newer stuff is not like it was in the old days. I have some very old plate stock from Europe that is some of the cleanest steel I have ever worked with.
whenever anybody tells you that you can have a deeper understanding of your craft by limiting your knowledge, the absurdity of the conversation should be self evident. QUOTE]
I agree with you. For a deeper understanding, I think science and knowledge are the ticket. Physics doesn't lie.
