You can get a diamond stone or lapping tape, which can be mounted on Edge Pro. A small DMT stone can also fit in.
Please come back & post if you ever get it as sharp as the VG10.
I can’t, up to DMT EEF, deburr on the same.
OK, I learned something else new. I apexed the edge at 30 degrees on my sharp maker with CBN rods, and I had a tiny burr. After I was sure It was apexed at 30 (15 dps), I gave it a few light strokes on the fine (white) rods at 40 degrees, maybe 5 or 6 strokes per side. Now it will push cut receipt paper.
Well,
I went back to EF (1200) and then to EEF. It got sharper, but still not at VG10 or even M4 level.
Hey. For the longest time i could not get my s90v and s30v as sharp as my vg10 and s35vn. I just attributed it to the steel. But in my case i learned that i still had a tiny, tiny burr that i could not see or feel. The burr would become visible only when i would shine a bright light at the edge. Then i would make very, very, very light, lighter than the weight of the blade, strokes until the burr was gone. I would use the corner or flat of a sharpmaker rod to do it. Suddenly i could get my s30v and s90v as hair popping sharp as my vg10. It would chop down arm hairs without touching the skin. But even though the vg10 delica may have still been sharper, the s90v would slice through paper towel nicer.
My biggest issue with s110v is small microchipping. Very light pressure and maybe a few passes on fine diamond lapping film or diamond compound can make a huge difference. Normally I apply a microbevel with the EEF, very light touch. Burrs not really a problem, but the edge forming up rough can be.
Martin,
Thank you. I’ll keep this in mind as well. Strop with 3micron diamond after EEF perhaps?
Chris, maybe.
Gotta take a close look at the edge coming off your last stone. This is a steel that tends to be HT'd pretty hard, and while tough it does seem prone to chipping on the fine abrasives with anything but super light pressure. The chips being extremely small. I've had best luck leaving this toothy somehow - either stop at a fine Crystalon, or I'll take it up to a fine DMT and then right to a microbevel on EEF using about an exhale's worth of pressure on the micro passes. Edge is still plenty bitey but treetops hair in piles.
Chris, maybe.
Shooting for a real polished, uniform edge - definitely some stropping or lapping film to finish IMHO.
Do the EF grits in the 1K to 1200 range not even add much value to these types of steels? I noticed last night in another thread, Jason had something similar, basically go DMT coarse straight to strop with compound, cutting out any "EF" type of step. I actually tried this last night on an M390 and it worked. So now I'm wondering if EF doesn't even really add anything. Just go from something coarse straight to a high-grit finishing option.
MHO - when apex width is less than particle diameter, edgy exposed particle is more durable than exposed spheroid top.
