- Nov 13, 2015
You guys have me reading a thread from 2009 thinking it recent
In very general terms, hardness always comes at the cost of toughness. And vice versa, for that matter. It's just the way it is. And it's the reason why it's worth the effort to evaluate how you're going to be using a particular blade before you set the specifications.
From what you've told us thus far regarding your intended uses, your blade is not likely to be subjected to large lateral stresses. As such, you can sacrifice some toughness for edge retention if you like, making 110V a fine choice, assuming you stick with any kind of halfway reasonable edge geometry.
S110V will hold an edge longer than any other steel I'm aware of but it's a challenge to sharpen. S35Vn will take a very fine edge with a lot less effort and hold it as long as S30V.
CRK has proven the utility of S35VN for many years.
s125vn, rex121, maxamet and a few others will hold an edge longer. But also different factors like heat treatment, edge geometry etc will make one out cut another too.S110V will hold an edge longer than any other steel I'm aware of but it's a challenge to sharpen. S35Vn will take a very fine edge with a lot less effort and hold it as long as S30V.
So has many other steels been proven. The only knives I like in s35vn are crk's... And I wish they would make a change because it's so common now and I regard crk as a premium brand and expect the keep an above average steel type and heat treatment due to this.CRK has proven the utility of S35VN for many years.
