BluntCut MetalWorks
- Apr 28, 2012
Below 600 grit, I mostly want to plow/excavate steels, so sharp+cheap abrasive works best for me. SiC waterstone satisfied both cheap & sharp. Diamond offers short-live sharp, therefore ain't cheap. At this coarse grit - Sharp SiC works better than dulled diamond.
At the coarse end of the spectrum: Is it conceivable you'd get the best possible results with high carbide blades, if you just used diamonds end-to-end, not even using a SiC stone for the coarse work? Just speculating here, but interested because I've been using my Crystolon for all my coarse work (regardless of steel type) recently. It certainly works. But if we're going for "optimum results" on high carbides, and only diamonds/cbn will cleanly abrade the carbides, it seems like the quality of the edge finish that you get from your coarse stone sharpening might be better if you used diamonds there, too. Which would lay a better foundational edge for your later sharpening.
Thoughts?
