- Jun 16, 2006
It's an awesome steel. Really holds a nice edge, not to hard to maintain. There's a reason why almost every major American knife company uses s30v as their premium steel.
S30V is a great steel no doubt. But whatever Victoronox uses it is also great and holds a terrrific edge.
Well, After 3 years using a SOG Twitch XL (AUS8) as an edc and then rotating to a Leek S30V. I can tell you that S30V is huge pain to sharpen properly compared to AUS8. It may keep it's edge longer but when it gets dull, it will be harder to sharpen up. It's probably a great 'Survival Knife' Steel but for EDC I'd rather have a Carbon Mora or My Twitch AUS8.
I'm trying to stay out of this one HoB!
I've had bad luck with edge retention with my S30V knives. I've never had the chipping problems that others have had, however.
There's an old rub about D2 (which I completely disagree with) that says it takes a crappy edge and holds it forever. My experience with S30V is that it takes a crappy edge and holds it for 2 cuts. Obviously, that's an exaggeration, but true in general from what I've seen.
I've sharpened it on DMT, ceramic, and waterstones (edgepro), and only the edgepro gets me a good edge. I find it *very* difficult to get a good edge on. It loses it's edge fairly quickly, from my comparisons (non-scientific), I rank it with AUS -8A. I was planning on doing more testing, but I aggravated an old elbow injury, and don't really want to try again. I'm tempted to offer a couple of these knives to some enterprising soul who wants to compare them on the same test.
The knives I've used are: Buck 110 and Vanguard, small Sebenza, Spyderco Native (Walmart), and Spyderco Manix. I gave the Manix away to a friend when he graduated from the Police Academy. The best in edge retention are the Bucks, the Sebenza the worst (by far). I had the Sebenza re-heat treated (it went from 57 to 60.5) and Krein thinned, and that helped a lot. But it still wasn't up to my Queen or Dozier D2's, so I got rid of it.
I think with the right grind and heat treat (above 63 HRC), you could possibly see great things. Phil Wilson sure has, and he knows a lot more about these things than I do. What is really unreal is that:
1. Fallkniven's 3G is close to S30V (from what I've heard), and I have nothing but praise for it. It's a *great* steel for edge retention and ease of sharpening - close to 3V.
2. Almost everyone else on BF hasn't seen this, which makes me wonder if I wasn't nuts when I was using it.
I don't know. My personal opinion is that S30V is crap. But most everyone disagrees, and it makes me question myself because a lot of these people are folks whose opinion that I value. A lot.
Maybe it's time I dusted off what I've got left and try again...
Not as long as it sells.
Keep in mind that there is a good range of hardnesses that different makers/manufacturers run on their S30V knives. S30V at HRc 55 probably wont be noticably better than 420HC at the same hardness. Holding a hair shaving edge depends mostly on hardness.
To answer the question in the title of the thread, there is some hype to S30V, but when heat treated optimally for the intended use of the knife, it can live up to the hype.
Sodak, was it you that said the line about D2 should read "it holds a crappy edge forever, after the good one is gone" or something like that?
I cannot be critical of the comparison test since there is not enough information to really try to explain the results. I would like to know the hardness of both of the blades. Based on my experience CPM S30V performs best at RC 61. Someone mentioned a S30V blade at 63 would be a good performer. I have not been able to push it that high. Normally the best as quenched hardness is about 62 and with a temper at 400, you end up with 61 +/-. On the CPM steels, 10V can be finished at 64 and CPM 154 up to 62 with good hardness toughness balance.
I just did some quick testing on rope with 4 blades of similar geometry all sharpened with Silicon Carbide stone and the wire edge removed with an India stone. To get an idea of how 440b would do I used an America made Dexter fillet knife. The steel could be 440A or 420HC. Hardness measured at 57 on my tester. This should be pretty close to the 440B blade. The other three knives were a CPM 154 (r 62) fillet knife, 154CM (r 61) fillet knife, S30V (61) and 10V (63) Coyote Meadow utility hunter. All were 0.010 behind the edge. I marked off 4 inches of cutting length. Cutting media was 5/8 manila rope. I cut on a scale to measure the down force. In the past, I have cut to 25 lbs and counted the cuts to compare the edge holding. This time I only went to 20 lbs to get a feel for how the Dexter would compare to the other higher carbide steels. Here is what I got:
Dexter 30 cuts
154CM 70
CPM 154 80
CPM S30V 70
CPM 10V 120
You can see the results follow the hardness. Past experience says that the higher carbide blades will tend to plateau out and continue to cut with higher force. If the Tinker is around RC 60 and very thin and the other CPM 30V blade is 58 or so then I could see how when cutting cardboard that one might get results similar to reported here. Cardboard cutting tends to favor a thinner blade and rope cutting is a better test for a higher carbide blade
Some thoughts on CPM S30V. This one has been pretty beat up on this forum. Results have been all over the map. I initially reported that this is an easy steel to heat treat. I still believe that. Compared to say S90V it requires a lower temperature and has a higher obtainable hardness. It also is less sensitive to quench cooling rate. All this makes it more forgivable. To get the best out of it I have a method that has given good results even on very thin flexible fillet blades.
Pre heat at 1500 and hold for 15 min.
Ramp up to 2000 to 2050 depending on your furnace controls and geometry
Hold for 40 min
Quench with forced air down to handhold temperature. Continue to cool down in water to about 60 degrees
Sub zero in Liquid Nitrogen for at least 2 hours. (note this step for me is quality control and others may argue that it is optional for this steel)
Warm from subzero temp in water
Temper at 400 for 2-hour cycles 3 times.
I do an initial rough grind before heat-treat but leave some material to remove after heat-treat. Grind at least .020 off the edge. I do one final temper after finish grind and polish to remove any residual stress from grinding and finish. Sharpen blade and do cutting tests on rope and do a twisting cut out of pine or fir to check for chipping. If there is evidence of chipping one final temper at a little higher temperature to improve toughness. The temps are specific to S30V but I follow the same general steps on all the CPM steels.
I like S30V for general use hunters and working knives where abrasive wear is in play. S90v and 10V are upgrades for this application. I recently did some major fiberglass repair work on my boat and used a couple of shop knives to trim cured epoxy glass. My 30v (61) and 10v (64) knives just kept cutting on this hard abrasive material. This is tough work for a knife. I favor CPM 154 now for fillet knives and kitchen knives. It has a little higher obtainable hardness and heat-treating is simplified since Turco can be used in place of foil for de carb protection. It finishes nice with less grinding belts and has great toughness even at RC62. It all boils down to the right steel for the application. Cpm S30V is still a good fit between the finer grain lower carbide steels and 90V and 10V. Phil
When you cut does edge hit some wooden base?
If so I suggest you to make something like this
otherwise you are not cutting rope but base and impact from wood is much higher and random in such case.
Thanks, Vassili.
Vassili, I did not go into detail on my testing set up since I have described it before. Yes I cut on a wood surface. I use Alder and I'm sure it does have some effect but it is the same for all the blades. It just acts like a stop if you ease up on the pressure after cutting the last few strands of fiber. I like your idea though, it takes out one more varible.
Vassili, I have been experimenting with cutting leather. This is a slicing cut comparing several knives on the same pc of leather. The idea is to cut a flat piece without going all the way through. The blades have to be exactly the same with the same length "belly" on the blade. This takes some feel and practice. Leather is more abrasive than you might think and you can quickly get an idea of how a knife might work in the field on say a skinning job. In general I have found that the results follow the same general trend as rope cutting. Higher hardness and higher carbide percentage hold up longer. This is a pure wear test, not enough force to roll or chip a fine edge. So far I have just done 300 slices with each blade and feel the sharpness with my thumb pad every 20 cuts. Don't laugh, you will be surprised how you can feel the degregration of the edge. If you want to try this just pull your thumb pad along the edge very lightly. If it grabs it is sharp, and you can tell with in about 20 slices when the edge starts to smooth out. Not science and many may scoff but I think it is a better indicator than cutting thread or measuring force on a scale. PHIL
