earan said:
Dan Gray,
that's your personal experience and i do respect that.
mirror finish, i do the final thicknes by surface grinding. so mirror finish is not a problem.
you've said that 440C doesn't comes close with CPM154 in steel makeup but duplicate with ATS-34. if i have to based it on admiral steel, they are the same. they have the same elemental composition. just a little +/-% from different makers, that's what i call equivalents.
I guess the point I was making is when you said
earan said:
154CM out-classes 440C and ATS-34, YES I AGREE!!! because they are of same grade or equivalents... .
when you put 154CM above ATS34? as "out classes it."
154CM is the same make up as ATS34 much more so than 440C is.. the two
154CM/ATS34 and 440C are of two different animals
and in knife making has won it's own places of use..
so the make up is scrutinized greatly and not generalized..there are many threads here that show this..
it's been talked about, the difference in industrial use versus knives and why our process differ from one and the other..
which would be your point in what you use it for at your job..
all steels have it's place, that's why there are so many of them in the first place.
We as makers have the task of determining what steel is good for what knife used for what task. one steel will not fit all knives and do it well..for all users and different levels and tools at hand..
I just want the reader to know the differences and similarities when they are put into comparing each other, 440c has it uses and 154CM and ATS has it's place as well as S30V..
on mirror polishing
I too have and use a surface grinder so on either steel ,, I'm talking apples to apples ..Which is easier of the two? if given the same tools to work with...there are many here that do not own a S/G ..
yes it would be easier for you and I..but still the two are at different difficulty..
so it would be of a great concern to them that don't..
using
either of the steels concerning toughness (in the need for knives as that is what these forums are concerned with)
is well into enough toughness, IMO , if you use them as knives are intended to be used..
so that for me would leave,, easy of use ( grinding), cost with edge holding ability,, all in combination.
still, again if a customer wants S30V I don't have a problem doing that
he's going to pay dearly though in comparison..is it worth it to them as the user,
this I will explain on a per order bases if it comes up..
just my 2 cents...
