Cliff Stamp
BANNED
- Oct 5, 1998
I wouldn't be surprised if S30V's high wear resistance causes an 'overcooking' of the edge with power sharpening.
This was one of the reasons given by Crucible, however they promoted S30V for ease of grinding over 440C. The companies using it had also used hard to grind steels like D2. The real problem is in the reported hardness, they have been checked and found to vary from 55 to 63 HRC. You would expect such a wide swath to generate a pretty radical spread in performance.
My question is: does the chipping that occurs in some S30V blades become any less after several uses (dulling of the edge) and re-sharpenings?
Sometimes it goes away, some times it doesn't some times it actually is fine for awhile and then starts chipping. My small Sebenza for example was fine for a long time but now if I attempt to hone it on the Sharpmaker the edge just fractures.
Are you talking about variation in all steels (from the same mfg), or just variation in S30V.
I would assume there is significant variation in all steels. This has to be the case because otherwise you have to assume a lot of people are lying. For example Thom and Sodak have described to me very different behavior of VG-10 at low angles than what I have seen. I would find it much more likely that there is a difference in the steels we are using than both of them are engaged in a conspiracy to defame the steel. I have also checked this personally by comparing several S30V and ZDP-189 blades from Spyderco and there is enough variance that while on average the ZDP-189 blades cut significantly better on cardboard, the groups actually overlap so it would be reasonable to assume that some customers could get equal performance or that rarely even some could see better performance from S30V.
I've seen your threads on S30V chipping. Have you seen other steels chip under similar levels of stress?
Not even close.
I'd also like to know more about the chipping problem. I have one S30V fixed blade that I've really beat on, chopping at a hard oak pallet. I couldn't get it to chip, and I think that's about as extreme as I will ever get with a knife. There must be some unknown variation in the steel or heat treat if chipping is happening with normal use.
The chipping happens at times even when sharpening and at other times under very light use like cutting cardboard, light vegetation and plastics. Edge geometry of course plays a large role, if you make the edge thick and obtuse enough then anything will be durable.
-Cliff
