To put this into perspective, the same sheet shows O1 with a grainsize of about 0.7 microns and no aggregation.
Yes, I actually know that, but it's good you point that out. It seems that these terms are often used interchangeably. It seems a lot of people talk about grain size or "fine grained" steel, when they actually refer to the carbide size. It seem to me, that maximum grain size and minimum carbide size should be the ideal combination...which of course is not possible with a high carbide volume, since the carbide volume should limit maximum grain size (well except of course, if all the carbide is sitting around in large clumps).Grain size and carbide size are different, the grain size is the size of the crystal structure of the matrix, the carbide size is of the precipitates in the matrix. -Cliff
Why is that?It seem to me, that maximum grain size and minimum carbide size should be the ideal combination
I think s30v is overrated. And hair poping sharp is NOT the proper edge to have on a knife.Itll NEVER stay that sharp. purly for showing off. and paper cutting is the worst thing for a blade. itll dull it quicker than sanyhting else. For a actual using knife, id get it poping sharp and then add a VERY slight alternate back bevel, like what one would do on a wood chisel, cuz then itll stay sharp much longer,and definatly WONT chip. I have had complwte success with this method. If yoy do this i can guarantee you the s30v will impress you. But ill say again, Nothing stays hair poping sharp for long. any custom maker will tell you this. you should be able to shave hair,of course.but theres a practical limit. I know, we all like to see how sharp we can get our knives,but if you just add a slight back bevel(say one or 2 very slight strokes at a shallower angle(careful not to press too hard,better to go lighter than harder,definatly. try it a few times,and youll get the hang of it.and that baby will stay sharp for a loooong time.a few strops here and there is all youll need. Anyhow, im so glad for this site. Take care yall, Ron
You generally want the minimum grain size as it increases strength and toughness
-Cliff
knarfeng
afaik the metal is pressed to 100% density before sintering or while they sinter it (or atleast should be)
My question was, "Are we sure that it is and they are?"
The grain boundries act as obstacles to slip processes such as gliding dislocations so they increase strength. There is no actual limit to grain size, if you held a steel at temperature during austenization the grains would continue to grow as the larger ones consumed the smaller ones and eventually you would have basically one big grain. You actually alloy steels to prevent this, the small amount of vanadium in many cutlery steels for example (AUS series) is to keep the austenite grain small because the small vanadium carbide will pin the grains and keep them from growing. This is why the fracture grain size for F2 is less than 1095. There is nothing stopping you from ideally getting the sme grain size in 1095 but there is nothing in the steel to keep the grain size small unlike F2 which has tungsten to pin the grains which is why F2 is 10 and 1095 is 9. The big problem with grain boundries is keeping them free of carbide and impurity segregation, those are the reason for the two main embrittlement regions in steels.
-Cliff
And if one wants to buy an nice high end knife, so many use S30V that there isn't really much of a choice.
I just wish some of the steel manufactures would join in.
Most custom makers will use a variety of steels, even in production knives there are M2, D2, ZDP-189, VG-10, etc. . What is the shape of the damage on the blade? Is it possible that someone else was using it?
-Cliff
