That's not true. I've had three S30V knives with brittle edges that chipped readily and often for no reason I could think of, and they never went near any belt sanders.brewthunda said:In the current issue of Blade they say that the online complaints of chipping S30 turned out to be caused by people trying to sharpen their knives on sanding belts and ruining the heat treat of the edge. That was the first I had heard of this and I don't recall seeing anything about this sanding belt business on the discussions located here.
Nikokurausu said:So if one wanted some blades with S30V what should one be aware of as to care and sharpening? I've ordered a Swamp Rat Rat Trap and reviews I've read seem to indicate that SWKW has their heat treat down but I also have my eyes on a Rukus and Manix which are S30V also.
W.T. Beck said:So it was a problem with the heat treatment?
Cliff, I'm not sure how you define "many people", and I can only speak for Kershaw, but we have not had any chipping issues with the S30V that we have used. On the contrary, we have had many compliments in concerns with the performance of the steel. We rather like S30V, and have more projects slated to utilize it. This is not to say users haven't had chipping issues, but at this time, I would caution in putting that edge chip "label" on S30V.many of the people who are having problems either switched to other steels or even had the knives rehardened.
Although I agree with this statement Cliff, I would also add that ZDP is not going to be as accessible as S30V. Currently all manufacturer's can use S30V for any project, at any time, and most are. ZDP-189 on the other hand is almost impossible to get, with lengthy lead time being the norm. Most companies are not going to be offering ZDP, even in limited production. I can almost guarantee we would have varying reports from consumers should multiple manufactures be using ZDP on a regular basis. Unless there are changes with the distribution of ZDP, I don't see volume of this steel being used, thus at this time, I don't think you can compare the 2 steels from a volume production standpoint. ZDP just can't be had in volume. ZDP is hot right now, but your selection is limited, and I don't see that changing anytime soon.ZDP-189 is also now more of a hot steel than S30V and offers a much higher hardness and does better on CATRA tests from Spyderco.
Cliff Stamp said:Now if they mean that the manufacturers themselves burned the edges, this was proposed by several because of the low grindability of S30V but it has severe logic problems.
