S30V was Chris’ first steel that he helped develop.I’m happy with it, but S30V is still my favorite!
Actually I'm not. I think it will be less desirable option after S45VN->Magnacut. But to be honest, I'm considering to buy the NIB S31 with S35VN since there are no other options in stock.Heh.. people already hedging bets for "value retention" these are not rare knives..
There are other options, in fact I would bet that monkeyedge has some on their website (large 31s)Actually I'm not. I think it will be less desirable option after S45VN->Magnacut. But to be honest, I'm considering to buy the NIB S31 with S35VN since there are no other options in stock.
Thanks, but I'm chasing a small PJ 31 and being in Russia, it's a bit challenging. I have Umnumzaan with S35VN since 2014 and pretty happy with it. For the urban EDC the edge retention of S35VN is more than enough.There are other options, in fact I would bet that monkeyedge has some on their website (large 31s)
You aren’t really missing much of anything outside of a minor increase to edge retention, and substantial increases to toughness and rust proofitiude. Ive never seen anyone break a sebenza or rust one though.Yup- like my S35VN so much that I don’t know what I’m missing otherwise.
That’s how I see it- my daily carry stuff is 1095 and SAK steel, so the improvement there is huge. I imagine there’s diminishing returns.You aren’t really missing much of anything outside of a minor increase to edge retention, and substantial increases to toughness and rust proofitiude. Ive never seen anyone break a sebenza or rust one though.
That might be true, it’s hard to tell with the steel being relatively new. Ive had issues with S30V chipping, so far nothing with Magnacut. CRK does run their Magnacut at a higher HRC so it could be weaker. Time and testing will tell.I expect the biggest advantage of improved toughness Ins folding knife is edge chipping. I have chipped the edge of S35VN, it sharpens right out, but improved toughness probably resists chipping
Like it......yes........pay $500 for a folding knife built out of it in 2023........nope, not even $250. For me when I'm knife shopping if you're using S30/S35 the price better be under $150, because for $200+ you can get better options. Much better options for those that both abuse their folders and want max toughness or something that holds an edge longer. That said it depends on your use. I've never broken or seriously damaged a folder in my pocket knife use, and I'm not field use abusing a CRK folder. So I'm not really interested in super tough steels that don't hold edges unless they are hard use fixed blades. I also don't see a huge advantage in easy sharpening softer steels in 2023 when there are so many easy amazing sharpeners. I can easily put an edge on most of the super steels with a wicked edge etc. and maintain it with a sharpmaker (or smaller similar sharpeners) and strop, so that's field serviceable enough for me. Now increasing toughness and edge holding, that's a win because you can put a thinner edge on that still stands up.
I've never understood the allure of "easy sharpening" for a couple decades or more we've had sharpeners that will sharpen any of the super steels fairly easily that are small and field portable. You can get DMK diamond pocket flat plates or rods that will easily sharpen/maintain the super steels and it doesn't get much more field portable. It's not like you can keep S30/35 sharp long just stropping it on your pants. So I just don't see where a soft steel that's easier to sharpen provides any benefit, unless you are trying to find something for the apocalypse that you can sharpen on the back of a notebook. To me it's simply trying to convince people why they want cheaper materials on a really expensive knife.
Agreed, CRK is one of the few knives at the price point that I really feel offers something other mass produced knives don't. I personally feel some of the other similar priced big name custom/mid-tech's don't live up to the hype/price point at all. I don't feel like I need to "get rid of" my CRK's because they are S30/35 steel, it's good steel, but I can say I wouldn't buy one now unless it's MagnaCut knowing that is/will be an option.
I do value being able to touch up an edge, but I think there's a lot of edge retention steels better than s30/35 that can still be maintained easily with a sharpmaker/strop setup. The trick with the sharpmaker is as long as you don't have to change the factory bevel angles it works great, but if you have remove a lot of metal, even s30 takes forever. I'm lazy, I won't take an hour with a wicked edge every time my blade gets dull, I'd go insane. I mostly use it to set the bevel/angles I want and rely on the sharpmaker to maintain. I'm able to do that with M390, 20CV, 204, s90, M4, etc. Maybe it takes a bit longer, but only a couple minutes if that. So at least for me I don't see a big difference in "ease" of maintaining an edge between say S30/35 and those above. If you have to change angles, or sharpen out blade chips, that's a different story.
Nothing wrong with the sharpmaker and a strop. Many knives have been maintained that way for a long time. I think the point the other guys are making is that most any steel can be maintained with your tools, provided that the factory geometry is compatible (i.e. 20 degrees per side or more acute) and that the edge is not significantly damaged. Sure, magnacut at 63 hrc might take a few more passes than the s35vn at 59, but it would only be an investment of a few extra minutes. The same could be said of other steels from other knife makers.I think you are much better at sharpening than me!
