Âchillepattada;13035614 said:Hello everybody and HAPPY NEW YEAR
Happy New Year to you also! Thanks for the beautiful pictures.
How are those knives traditionally carried, dropped free in a pocket, or is there a sheath involved. I ask because of the pointy barehead end of the handle. Seems it would not take long to put a hole in a pocket.
This particular knife, though, looks very Spanish to me...
good insight. You triggered a search for the location and chronology of these knives:
Spanish navaja originates around 1700. Early navajas had no back spring and no lock, similar to the Pattada and the Opinel.
A) Lier home of the Lierenaar, 1700's
B) Laguiole home of the Laguiole, 1829
C) Pattada home of the Pattadesa 1850's
D) Saint-Jean-de-Maurienne, home of the Opinel 1890
At the time the Navaja came into existence, Spain was ruled by the Senior Hapsburg family and their territories included parts of Belgium, Sardinia, Corsica, Italy, Sicily, Montpelier and Provence in southern France.
Montpelier is on the way from Laguiole to Pattada, through the port of Marseilles.
Saint-Jean-de-Maurienne is reached from Corsica by going through Monaco, or from Pattada by going through Marseilles. I believe these were all Spanish territories at one time. See the following map, showing the Hapsburg territories in the year 1700
here is a navaja with a pull ring to lift the external lock spring, before the pivoting lock release lever was developed, note also the leaf shaped blade
pivot lever navaja, external lock spring.
modern Spanish made navaja variant with slip joint back spring and no lock, Aitor Castor. Note leaf shaped blade, exposed pivot pin, and drop handle, as well as the back spring set between slab handles
Belgian Lierenaar originates in Lier in the 1700's
note the drop in the handle, reminiscent of the navaja and pattadesa. Note also the surface mounted lock spring in following image, top, and the older variation, with the lock spring set between the scales.
Same here! My blood pressure rises just a little, whenever I see this thread's title in bold.I get excited every time I see this thread pop up!
