- Nov 16, 2002
Hi D! Just sent my email about the 4261 P BK 10.25" chef knife to them. Hoping to own one soon. How's your chef knife working?
Hi Broos,
Apart from the good old HRC-tester there is not really alot of good testing machines for knifes or steel that generates a good answer. Impact test for toughness is ok but difficult to translate to any kind of real world values. In fact I kind of like the ABS toughness test where they put the blade in a vice and bends it, but even with such a test the geometry of the blade must be the same for all blades in order to make a fair comparison.
And of course the CATRA, well I'm not really a fan of that one. The one cutting rope is better then the one cutting sandpaper at least but I cant say I like it much. And I'm not sure it even tests wear resistance.
I would like to see more standardized testing but there isn't much out there for knife steel.
//Jerker
I agree CATRA does generate some strange results.
Despite this thread being a year old, I'll ask what CATRA results are you referring to as strange? The only CATRA test results I've ever seen released for blades of equal geometry are the Diamondblade tests, and they do not seem strange to me given known or assumed HRc's or wear resistance.
Now what does seem strange (and for me puts doubt on the entire test regimen and all the test results) to me are some test results where knives with lower hardness and lower wear resistance get better edge retention results than a knife with harder and more wear resistant steels - now that doesn't make sense to me.
To me the primary purpose of a knife is to concentrate a massive amount of force onto the microscopic edge that is 0.4 microns thick, ie. cutting into material. This would be primary influenced by strength (proportional to hardness), and is not the same phenomenon tested by the CATRA.
You have oversimplified it.
The inherent edge retention of an alloy, as Broos points out, is most often a combination of hardness and wear resistance. That is true in the real world as much as in the CATRA tests. There are types of cutting that depend on one more than the other. Some types of cutting are dependent on hardness, other types on wear resistance, but most often both factors combine to provide the edge retention.
