Jerker,
Can you explain how you came up with your ratings on edge stability? I have looked into this and asked about this steel characteristic but have not got any detailed information on how it is determined or tested beyond Mr. Landes' descriptions provided here a while back (he described a test that applied a lateral load on the knife edge, but didn't explain how the results are measured or observed). I'd be interested to hear how you have rated this, or any insight you have on it.
Thanks!
Hi Broos,
Larrin answered you quite good here I think but I'll add a comment or two.
Carbide size and carbide volume are, as Larrin said, very important for edge stability. Large carbides will tend to "come loose" when enough force is placed on them. So large carbide steels will have lower edge-tability than fine carbide steels. But I can't present any nice test results for this, but we do have experience with this phenomena so it's a familiar behaviour for us.
High carbide volume will mean that a crack easily can jump from carbide to carbide with only small areas of steel matrix to slow the propagation of the crack. The steel matrix (matrix = stuff holding the carbides in place) will resist cracks. Imagine a steel with 100% carbides, that would be a ceramic. Wear resistant but too brittle for most applications. No carbides would be a carbon steel (not 100% true but close enough). Tough but with limited wear resistance. With a high carbide volume the steel shows "ceramic" behaviour, like edge-chipping. PM steels will perform closer to ceramics than our fine-grain steels due to their high carbide content. This will then mean that they are more prone to edge-chipping than our steels. I have no way of actually testing this to get nice scientific data, I rely on my theoretic reasoning. And more than a few steel analysis we have made of competing steels.
So far I have pretty much just repeted Larrins words. But there is also another aspect. If an edge does not chip it WILL roll at some point. Resistance to rolling is hardness. So fine-carbide (or no carbide) with high hardness will excel at resistance to edge-rolling.
The combination of resistance against chipping, carbide tear-out and resistance to edge-rolling are the three key points i have used for my grades of the different steel types.
There are others which I have not mentioned that will play a smaller roll. Like carbide shape. Round carbides is better from a toughness perspective than pointy ones. Even carbide distribution is also important, if there is excess carbides in the edge it will easily chip and if there is a deficiency in the edge it will decrease wear resistance for instance.
Puuh, long answer to a short question. To sum up, no we have no scientific way of measuring edge stability. It comes from theory, years of observation and our more or less qualified guesses.
//Jerker
