don't support clones, the 7010 is clearly a crk clone
Politics, legalities and intellectual property factors aside, these two knives appear to be pretty similar in terms of materials, design and price point.
Has anyone had the opportunity to compare them ?
Thanks in advance
I have all three knives, SRM, CRKT, and CRK. From a utility standpoint they're all about the same. I wouldn't say any of them cuts any better than the others. The drifter is a recurve, which obviously gives you more belly but also possibly more sharpening headache, unless you have a rod system like the sharpmaker or something similar.
Of the three, even if it doesn't cut any better, the CRK feels nicer, in that tight but smooth sort of CRK way. All three feel very similar in hand, about the same dimensions and weight and construction. My 710 came with a slightly messed up edge grind near the tip (you can see it in the photos) but it also showed up sharper than the CRKT. The clips on the SRM and CRKT are tip down (boo!) but the CRK can be clipped in the proper direction.
I don't have my small Sebenza handy, because I sent it out to have a paper micarta scale made for it, but here are the SRM 710 and CRKT Drifter next to each other (shot this on my phone just now):
Of course, before I forget to mention it, you shouldn't buy the evil clone. Get the drifter if you're choosing between the two--they're probably made in the same factory anyway . . .
Thanks in advance
What else is "pretty similar" to that SanRenMu is a Sebenza. The CRKT does not seem to be "obvious" so I would go with that one.
OP here.
Well, I'd like to express my thanks to evilgreg whose post answered all my questions.
" I have all three knives, SRM, CRKT, and CRK. From a utility standpoint they're all about the same. I wouldn't say any of them cuts any better than the others. ...All three feel very similar in hand, about the same dimensions and weight and construction."
I like the SRM/ CRK design a little better than the Drifter design so I'm sure you folks will be able to guess which of these three knives I will be purchasing. By the way the legal blade length limit in Boston is 2.5 inches, so I would never spend over $100 on a knife with a blade length exceeding that.
Thanks to all who offered opinions.
I should have clarified. For a knife with a blade length of under the Boston limit of 2.5", I would pay over $100, perhaps way over $100, if I like it. Right now I'm looking at customs and Three Rivers For example.There are plenty of non-ripped off knives under 2.5" in blade length for less than $100. Even some made by SRM for cheap. I guess I don't get it![]()
But for a knife that I could use a home but really nowhere else in my vicinity, no way I'm paying that much. I hope that clarifies my knife buying strategy.
So you like the CRK Sebenza design more then the Drifter design, but you dont want to spend more than $100, so you will get the sub $100 SRM that ripped the Sebenza design off.
To each is own, I guess.
Why should I spend that much money for a knife that I could use in my own home but not outside my home? I am quite willing to spend larger sums of money on knives that are legal in my community. For example I'm currently looking at the Dice and the Three Rivers LTC, and customs with blades under 2.5"
Just a heads up, both the Drifter and the 710 in my picture above are a bit over 2.5" (police will use from the end of the handle to the tip of the blade, usually, not the sharpened length) so you'd need to mod them to make them safe options.
When I'm trying to carry legal in Chicago or Boston (I end up in both cities semi-regularly) my favorite knives are the Spyderco Cat (~$40) and Cold Steel Tuff Lite (~$28), FWIW.
