- Feb 6, 2009
This is what in so far, I think this is going to be an organic thing since I will be adding and taking things from this tin as I run in to situations or learn new way of solving problems.
The super glue, ear plugs, zip ties, and the lighter (instead of the waterproof matches) are some of the things I have added after learning from what you guy have in yours.
I do know how to stitch up a wound, and I’d like to share this little bit on first aid stitching I found useful.
August 13, 2007
If you have ever been out somewhere and received a nice cut it is not fun. It is really not fun when you are out in the middle of no where, like on a fishing trip or out camping. Have no fear though here is a quick 4 step guide to helping you stitch that wound right up.
1) First, get the wound as clean as possible. Flush out the wound with water for between 3-5 minutes. The more water the better. If you happen to have a first-aid kit apply iodine or peroxide to kill any more germs.
2) Find a small needle that is no longer than 2 inches long. Sterilize said needle by holding it over a flame (lighter, camp fire, etc) for 60-90 seconds. Thread the needle with the finest material you have available but as a rule cotton gathers the most germs.
3) Your first pierce should be as far away from the cut as the wound is deep. Shove the needle through to the other side, pulling as tightly as possible, tying a knot and cutting the thread. Repeat every quarter inch or so.
4) Infection is your worst enemy after you have finished your stitching so keep it covered as much as possible. If it doesn't get infected you should be able to remove the stitches in about 2 weeks.
Ok... there are some things you're missing. First, you're going to need to irrigate that wound before you start to sew it up. How are you going to do that? You need a way to store/carry water. A non-lubricated condom works excellent for that. Also, you're going to need a way to attempt to purify the water. I'd suggest putting some iodine tablets in there, as well, for that purpose. Then, you'll need a way to actually flush the inside of the wound thoroughly. I'd suggest putting a small 5ml syringe in the kit for that purpose.
Having said that, the suturing method posted above is pretty incomplete, and also dangerous for untrained individual's to attempt. If you have a laceration that is severe enough to need closure (as opposed to covering), you should attempt to stop the bleeding (elevation, direct pressure, pressure points, etc.), cover the wound with a sterile dressing, and seek emergency medical care.
