You are a busy boy! Can't find fault with what you're up to either.
That's a great looking axe. I like it a lot!
No, it's surely a post-1966 axe. The flat cheeks are one sign but the clincher is the label. That's a Lewiston PA label - Mann Edge Tool town.
I've experienced the same feeling - handle too short for the weight of the head - on several small work hatchets like this. I think you're making a good decision.
Here's the weird part. This bit steel is the hardest steel I've ever come across in the axe......
Hardly anything would cut it, and some of the edge was basically flat/chipped off. I'm wondering if the Chinese supplier used some super hard tool steel, or if the heat treat went awry, as the bit seemed to have different hardness ratings on different portions of the blade.
This is a problem with recycled steel. It's likely an amalgam of numerous steel types and not well homogenized. Using a 'best average' hardening/tempering method will leave you with hard spots and soft spots. If it's part tin can and part old lawnmower blade then those steels are going to react very differently to the heat treat.
I would go ahead and use the angle grinder on that one.
"The Rough"
I picked up this Norlund at a flea market for a good price, and I believe it is called the Cabin Axe. I was looking for a boy's axe as I didn't have one, and this was the perfect size. Excellent brand as well, so a great little score! No before pics, but it was covered in surface rust, and the non-original handle was dry as a bone, with a missing wedge. Cleaned it up with the wire cup first.
Here's the handle with the head removed. Very, very dry.
So I sharpened up the edge, which seems like good steel. It has a very thin bit. I also had to file off some minor mushrooming on the poll...wasn't too bad through. I then sanded and added a few coats of BLO to the handle, and temporarily re-hung it for use if needed.
I say temporarily, because this is clearly not the original handle, as there is quite a bit of space left in the eye, even when re-hung. Oddly enough, the eye on the head is almost full-sized, and the Link boy's axe handle I got almost slid all the way through! So I think it will need to go on a cut-down full-size handle, or on a House Handle house axe handle. Either way, it's good for now. It seems to be a great little axe!
My father has this exact same axe. The eye is full size and specifically requires a miner's type handle. It took me some time before finding a suitable one to work with. Got a straight miner'ss handle from Tennessee Hickory. Will add a pic if I can find them. It is a very handy axe.
Edited to add: I'm pretty sure it is called the "Camper Axe". http://www.yesteryearstools.com/Yesteryears%20Tools/Norlund%20Co..html
[/URL][/IMG]![]()
Here's the refinished product. I will take a pic of the old handle, but believe its straight and approximately 24" long.
All that said, I think yours looks great!
