That is a fine looking pegboard set-up. You soaked the older files in vinegar then scrubbed them out with a file card?
I also just saw the trick for cutting a copper tube some from one end...hammering that end flat, and using it to get the really stubborn gunk out of files. I have a copper tube. I think I have a new mini project!![]()
It does look like they did a nice job for you. The cracks might be almost nonexistent if/when you thin it down a little anyway. You were saying that the hot garage might have an effect, and I suppose it could be that they rode around in a blazing hot USPS truck as well. But I've also seen HH handles on the shelf at the hardware store cracked all to hell, so it could be any number of things I guess.
I'm going to do exactly what you say, with some minor sanding between BLO coats to act as a filler.
Yes, they supplied some wedges, but I'm not certain on the quality...I'll snap a pic later. They are a little rough around the edges, so we'll see. They will need a little sanding at the very least.
Looking forward to seeing what you do with these SCT100. I have a 3.5# Lakeside on a 28" handle and find I use it more than other axes.
I wish the swell was a bit bigger, but it's certainly not an issue....
