The concept of an "all around knife" is really misunderstood. An all around knife isn't something that does everything well, because that knife simply doesn't exist. An all around knife is a knife that excels at what you do most, and will work for other tasks. Your all around knife and my all around knife will not be the same knife.
I've found scandi grinds to work great for everything... except food prep, especially chopping vegies. They are truly terrible at that.
But there's nothing in the world that cuts vegies like a flat ground Chinese-pattern vegetable knife. A knife which, incidentally, is pretty much useless for cutting anything else.
I've got several high quality convex ground blades, and all of them pale in comparison to a scandi for carving wood. Wood carving is not the only use for a scandi, but it's certainly where they shine.
If you mostly work wood with your knife then a scandi is a pretty good choice. It'll cut other things just fine (onions, carrots, apples and potatoes excluded) and be superior for wood carving.
A convex edge will do better at cutting foodstuffs, but be markedly worse at precision carving.
While it's temping to state that a scandi grind is only suitable for woodworking, the fact that millions of people have chosen to use that grind for centuries seems to disprove the statement.
It's different tools for different tasks. Try carving an ax handle with your favorite kitchen knife or filleting a fish with your end-of-the-world sharpened pry-bar and you'll find they are also less than ideal.
