me2,
I always have taken benefit from the reading of your posts. So it's with all due respect i give you my opinion: buying a Mora, for the price they are sold, isn't of a great risk for your wallet. I don't know if it could outcut anyone of your knives but it could surprise you if you use it for it's intended purpose which is, (have i already said it?) carving wood.
dantzk.
Flattery will get you a long way in life. Thanks.
http://www.bladeforums.com/forums/s...igh-Speed-Steel-Puukko/page2?highlight=Puukko
I made my own puukko (sort of) blade years ago. One update is that the blade is actually 0.04" thick, not the 1/16" stated in the review. I finally got some calipers. I pity anyone who tries to resharpen the entire bevel of a M2 puukko style blade by hand. You may have seen this thread, but I'll repost it here for the OP's benefit. I'm thinking of making another, but I'll use some annealed A2 I have left over and heat treat it AFTER grinding.
I understand the appeal of puukko style knives (scandi irritates the tar out of me). Especially based on tradition and such. However, I cannot see the advantage of a Mora over another knife of the same profile, but a slightly thicker blade, say 5/32" instead of the common 3/32", with a full flat grind and a 10 degree edge bevel. I try to be specific in the way I use terms, and I define a difference between ease of sharpening and speed of sharpening. However, I just can't see the logic behind wanting to remove steel from a bevel that's 3/8" wide vs. one that's 1/16" or less. I know the bevel is easier to match, but if it's that narrow, just change it to an angle you find more natural, and it will still cut as good or better, even in wood. I don't do a lot of wood carving/shaping with a knife, and I know control with a puukko style is a selling point, but use of less force is a bit part of control, for which I'd give the advantage to the FFG blade with a much thinner edge and the same edge angle. But, Mora's are so cheap, and that low edge angle, even on full stock blades, will still cut circles around a tactical folder with a 22 degree edge backed by a 0.04" thick edge. I can see the appeal, I just think it's gotten blown way out of proportion.
