Thank you Peter!Believe that is a 5/64
They really do go back together without much trouble and blade centered. They are the only knives I take apart on a regular basis.
That is exactly what I did this evening. Here are the steps I took.Just start by taking the cord off and leaving the pin in and see how you like it.
I am actually in the market for an umnumzaan. Is yours new or an older model? I actually like the idea of the lanyard pin staying inside the knife.When I removed the lanyard from my Umnumzaan, the lanyard pin just 'popped out'. Which I'm glad it did. I prefer the lanyard holes rather than having a pin there. Whenever I get around to buying a small Insingo, I'll remove that one's lanyard and lanyard pin, too. I doubt they all pop out like my Zaan's did, though.
Jim
A touch of Super Glue on the lanyard pin stops the rattle.
OK. I will have to try both and see how it goes. Super glue will be faster but might be temporary. Thank you both for the "noise" solutions.Easiest way to stop the rattle: leave a bit of paracord in the pin, burn both ends of the paracord, and it will stay secure and quiet
Wish someone made ti tie bars aftermarket that you could pop in there and it wouldnt pop out because it was like a barrel shape. I would buy that.
My Zaan's birthdate was in Oct. 2011, and I received it within a couple weeks after that.
Jim
OK. I will give that a try after I watch some videos and feel ready. I have the CRK grease, microfiber and Windex ready to go. Just have to get the nerve and drive to get it done. One thing I am worried about is, lock up. Mine is exactly half way and has not moved. I would like to keep it that way if possible. So far I am not missing my lanyard on my small 21!Staysharp, if I am correct, I believe that all large Sebenzas, and all Umnumzaans, have pins that will slide out without the cord on it. The small sebenzas have edges, or steps on the pins that keeps them from sliding all of the way out.
I would recommend watching and reading tutorials on how to take apart a CRK, and that way you can lube your Sebenza with CRK grease and leave it like new again.
On most of my CRK's that have a pin that slides out, I insert a price of paracord through it, and pull it until I have barely a hair poking through one end. I then melt it and I cut the other side so that it is poking out about the same distance. I melt that side too, and install the pin on the knife, and then put it back together like normal.
And that is how I keep my lanyard pin to stay in, and not rattle. I think It looks nice to have the pin in there on my CRK's that I dont already have an aftermarket lanyard on.
