Originally posted by 30-30 Cal.
Still, a knive can be too sharp to be really useful, can't it
You know, I've heard people say that before, and never quite knew what they meant. As far as I'm concerned, the sharper the better.
Maybe what people mean is that a knife that's really good at shaving might not be so good at other things, because it's too polished to slice or too thin to take any stress. If that's what meant, I can agree with it. But I think the big mistake is that many people use shaving-type push cutting as the sole measure of how sharp their knife is.
That's fine if your your knife is a straight razor; for any other knife, it makes no sense to make shaving your sole measure of sharpness. I always do at least one other test. I take a big piece of hard poly rope and see how far into the rope I can get with one slice. A knife super razor-polished and stropped will not do well with that test, so I have to rough the edge back up. This leads to a little challenge:
Getting a knife "scary sharp" through razor polishing may be the first major goal in developing your sharpening skills, but the real art comes in the ability to retain most of the performance of the razor-polished blade but with a blade that also slices hard materials well.
For reference, I find that most factory edges, and edges that are razor polished, often make it around 1/9 the way through the particular hard poly rope I use (that is, 1/3 through 1 of the 3 strands) on one very hard slice. The best factory edges I've tried make it around halfway through. I can get my knives to go 8/9 to all the way through, a 100%-800% performance increase (!!!). These are on knives that will still shave easily (often I get the slicing performance with a dual-grit finish rather than roughing up the whole edge). Since I'm mechanically inept, it's not because I've developed some mystical skill at sharpening, I haven't, I'm just picking the right grits and angles. I do not cheat by picking angles that will crumble for my intended use, or grits that don't make sense.
Back to the main point: With your sharpening set should be a piece of 1" hard poly rope. Taking a slice out of that rope should be one of your sharpening tests, right after you test how well your blade shaves arm hair. For your personal knife usage, balancing arm-hair-shaving performance vs poly-rope-slicing performance will be something you intuitively understand if you do this test every time, and you'll be able to fine-tune, with less compromise than you might think.
Joe
