- Oct 18, 2001
I should mention that grinding a full convex grind is not for the impatient types...it can really test your stamina. Takes forever to get the grind even.
Maybe this will help explain.
The best way I've found to make a full convex grind is to make a full flat grind first - leaving the spine thick. Then slack-belt grind it pressing the whole blade against the belt. This will take quite a bit off the spine. What you are left with is long gentle arc with no flats at all. It's at its thickest about 3/8" down from the spine (but it's still no fatso...
