"What would a knife look like, if it was meant to be a multipurpose tool for poor, run down space peoples in [this imaginary universe]? I'm thinking an 8" blade with a tanto point, saw edge back, and a smaller hilt. Main uses are stabbing and jamming, some sawing, lots of prying, and not a small number of fights with other species and humans. Coated in a non conductive material, these would be one of the most important things a human owns. Since I know less about knives, I ask you what you think the design should be, and what the most common uses would be. Thank you for help!"
'Stabbing' and 'Prying' tend to be mutually exclusive. It sounds as though what is really being looked for is a culturally distinct weapon/tool for this group of people.
Form follows function, so the more you know about this society and its environment, the better you'll be able to design something.
Is this culture space-dwelling, spacefaring, or simply living on sci-fi planet of some sort?
Is the knife primarily a weapon, i.e. a sword, or primarily a tool that is often used as a weapon, i.e. a machete?
If it is a weapon, what/who was it designed to be used against? If a tool, what was its primary purpose?
If a weapon, is it largely ceremonial at this point? If a tool, how everyday a tool is it?
What materials and technologies are available to this culture? Could this tool be an advanced alloy (nonferrous or not) with electrically isolated handle made from advanced composites? Or is it a sharpened chunk of scrap steel made from spaceship wreckage with an electrical tape handle?
First of all, apologies for a very long post.
Shipboard life
Near-term space travel will be regimented and routine: a job for everybody, and everybody doing their job, with lots of emphasis on checklists and safety procedures. It will be as boring as you can imagine, with none of the romance and glamor that pre-spaceflight writers were so fond of adding to it. There will be many knife enthusiasts on board ships, but they will leave their knives at home, or in long-term storage, because there is too much danger of a co-worker stealing them. With all the emphasis on safety, most companies will forbid knives of any kind, since something that makes a hole in things inside, essentially, a gigantic pressure vessel, is a bad idea!
Colonies
Mining colonies and other corporate ventures are, potentially, where you'll see the most variety of cutting implements, since people will have access to tools to make tools, and leisure time to use them.
Colonies that are established for other reasons will resemble the colonization of America, or Australia. Here again, the level of technical sophistication will vary widely, with some able to order expensive knives made on industrialized worlds, some having to knap their own tools from the local equivalent of flint, and everything in between. Prison colonies will absolutely forbid knives, and the improvised weapons that you see in those environments will tax anybody's imagination.
The knives
The actual composition of knives is a bit harder to predict. My guess is that there will be a move away from steel, and into unique silica matrices, or laminated materials that incorporate some steel, but only enough to give it the ability to flex under shock or strain.
With the advent of these materials, all-steel blades will at first be considered "cheap", and "not cool". The art of sharpening will mostly die out, since the laminated blades will never need sharpening.
With time, all steel blades will acquire a nostalgic feel, and a loyal following of their own. Freehand sharpening will return as an art among this group, with forums dedicated to the practice and exchange of information. Some makers will discover "old processes", used to shape steel into knife blades.
The majority of the human race will continue to use mass-produced factory knives that look and feel pretty much like what we've got today, but with much better edge retention. New materials will be used, but function drives form, and you gotta have a "holdy end", and a "sharp end", and that won't change.
Space pirates
Because, why not?
There will be some, especially in the early years, when ships are relatively slow, and communication takes a long time.
The space pirates will probably use something we would recognize as a trench knife. Shipboard combat will take place in long corridors, and the idea of powerful projectiles, or energy beams, that could pierce the hull, will be something nobody wants! So fights will be at arms-length, with nasty improvised weapons, made out of mass-produced materials.
I'd suspect that in space they would use knives similar to those that deep sea divers would use. Blades easy to access and use with thick gloves on and limited mobility.
A dive knife like my Blackie Collins Wenoka.
not my knife
It sounds to me like the "spacers" in question are the illicit scavenger types often seen in darker scifi works, not the well-equipped starfleet types that some people are imagining.
Somebody mentioned the Countycomm breacher bar, and that's exactly the kind of thing I'm picturing too. Just replace the flat tip with some kind of point and put some handle scales on it, and I think you've got the tool for the job. If the setting permits it I'd make it out of some sort of non-ferrous metal, maybe a super-hard titanium alloy, or even out of some kind of futuristic ceramic or polymer.
Corrosion is definitely a concern, there's a good chance these guys will end up on ships with inadequate life support and humid atmospheres, and god only knows what the planets they go to will be like.
I also don't think they all have to be handmade out of scrap or anything. I think they'd run the same kind of gamut that modern knives do, from cheapos made in the space equivalent of China to high-end customs for successful traders and crime bosses and the like. I do, however, think that almost all of them would be customized or modified to some degree, and some of that might be done with space junk. I also imagine a lot of design variation, and people would likely choose something that fits their needs, so somebody who stays away from conflict and does a lot of salvaging might choose something thicker and blunter, while a brawler might have a long, thin, and pointy weapon.
I would say for manufacturing no design would be off the table because at this point 3d machining of steel would be widely available and cheap.
Here was his original question:
But that does not fit in with a grungy, post-apocalyptic, humans as scavengers of the galaxy type of setting.
I mean, if we were going high tech, you'd just send in the nanobot swarm to grab whatever was needed, but that doesn't make for high adventure, with shipboard combat against alien scum, does it?
Remember the original question:
(bolding added by me)
