- Sep 9, 2003
I swear to you folks that I wanted to eventually post pictures of this one to show how one can effectively use scrap steel on really nice knives. I decided on this next dagger that I wanted to used straight steel for the fittings and do some nice textural effects instead of damascus, so I started looking around for some stock in my shop but I had none in the right size inside except for some slightly oversized 1018 that I have just a little left of. Then I got an idea, hey why not use something from my scrap pile to show that I am not a totally closed minded pinhead when it comes to recycling steel! A really ornate and well done dagger using scrap steel for the quillons and pommel, how creative that would be in a totally benign way. So I found a rusty old bar just the right size in my scrap pile and went to work forging it into a rough shape and then I spheroidized it just to be safe for the machining operations (although this can make low carbon stuff “gummy” what the hey, better safe than sorry). I spent a couple of days working this thing and had at all slotted out for the tang and decided to heat it with the torch to do some adjustments before final fit…
When I cleaned up the scale for the heating I found the cracks! I don’t know what this alloy is (I guess that is the whole point of this post) but it did not like being heated and air cooled around that machined slot! You can’t see it in the photo but all around the slot on the rough guard is a spider web of cracks in the steel, rendering it useless and wasting all the hours that went into getting it to that point.
I calmly (it took me many years to learn to do it calmly) walked into the other room of my shop and cut off the needed material from that bar of known 1018, all the while kicking myself for not listening to my own advice about mystery metal. I also chastised myself about the fact that when the dagger was done I was going to ask over $1,000 for it and I was too cheap to cut $0.75 cents worth of 1018 off from my bar. The second more finished guard is the 1018, which machined like a dream and was heated and manipulated as much as I needed with no problems.
My thought process got all messed up because it wasn’t blade material. Oh sure if it is the blade I will use nothing but the steels I can identify and know exactly how to heat treat, but the only criteria I had for the fittings was that it be soft enough to machine, but duhh… how can I know even that if I don’t know what it is? I still really do work with some scrap for certain projects but this is a lesson I just now learned about using unknown material even for the stuff I don’t intend to heat treat. I must stress that I am not telling anybody what to use, but if somebody can benefit from my lesson I thought I would share my bonehead move an allow others take from what they want.
