- Sep 9, 2003
J.T., Amusing story, but I fail to see how screwing up a machine by leaving a metal ruler in it compares to the feeling of loss after spending countless hours of hand craftmanship on something only for it to fail in the end.
I can see where the portions of humble pie it serves up would be similar. however
Kevin,
I personally would like to see a little insight on how you design and layout one of your daggers...maybe some tips on how to keep everything straight,crisp,and clean. I could go on, but don't want to drive you crazy...I'll leave that to Matt G.!
Thanks very much!
Mace.
Oh I see, is somebody looking forward to a certain project that may have use for such information?
Since I decided a few years back to specialize in daggers and rapiers for a while, and study what they were really all about and how the originals were put together, I asked the ABS last year if they would like me to do some lectures on that topic, they agreed and now my dagger lecture is probably my most done and best attended, I will be doing it again in a week and a half at the Piney Woods Hammer-in in Arkansas.
Just remember that daggers are all about symmetry, when you have four identical blade bevels, shoulders and plunges anything not identical from side to side will look much worse than if it were on a single edged blade. I approach my design more and more a from the original 16th and 17th century daggers I have studied, those guys really knew what they were doing when it came to making a fighting knife. Dont be afraid of making it thicker at the ricasso, this allows for more distal taper. Not only does that make a good stiff blade (essential for a real dagger) but it makes the tapering and the definition of the mid rib more pronounced. A thin blade makes the blade angles shallow and makes your job of keeping that midline crisp and straight much more difficult. Please, please, please use profile taper as well as distal taper, I personally feel that a MS judge should be able to fail a dagger that has parallel side down the length of the blade. what I mean is taper the width as well as the thickness, if your dagger is 1 at near the ricasso and 1 just a little bit form the tip it is just not correct for a dagger and looks rather amateurish. And the real kicker is that it is harder to do you distal taper on one of those parallel sided monstrosities. If your profile tapers the bevels are approaching at converging angles at the tip, so that they will naturally undercut each other in the grind and automatically form a beautiful distal taper.
I also think we should be able to fail quillon, daggers that only have little ½ turned knobs for quillons, as they do not serve the function of the knife whatsoever, and lets face it the maker took the easy way out. The extended cross guard on quilloned daggers were for catching and locking the opponents blade those little nubs cant do that. But everybody can breath easy on this one as the ABS set the standards for the dagger, not I. They are the ones you have to satisfy and they have very different ideas about the quillon dagger than I do. But I would be pulling for anybody who made wide quillons, and I would be cheering for those who turned them downward toward the blade, which adds significantly to the challenge of symmetry.
Grind your profile first and get your ricasso entirely squared and level. Then a quick and easy way to check fro straight and symmetrical is lay the blade on a long sheet of paper and trace all the way around the outside- tang and all, then flip it over and see where it doesnt match the tracing anymore. Mark those high spots and grind it accordingly until you match the next tracing exactly. Then from truing up the ricasso lengthwise on the platen you should have a flat line going down the blade at the center, LEAVE THAT THERE! Lay out your center line on it and then grind to it, but do not actually touch it until the later polishing operations finally have the bevels meet and erase it. If you are not really good on the grinder, use a file guide and a round file to cut in all of your plunge cuts and then smooth them out with a 220X belt.
These daggers where the quintessential blade of the renaissance, remember this when designing them, the golden mean was all the rage in European design, the more you work it into the proportions of the blade, the more European renaissance that blade will look. When you are stuck on how long or wide you want to make something just remember 1:1.618, (it makes for a great ricasso
I also think many mosaics and complex composites look like hell on these blades. These are some of my favorite blades in the world and I have a desire to see them done elegantly and tastefully, simple twists patterns and ladders look smashing on these blades! Besides, if you go with a composite you had better keep it TOTALLY symmetrical. If I saw a welded on edge that was totally out of whack from the other side I would indeed write no on the applicants card whether the other judges agreed or not.
Beware of helical grinds! The most common distortion on a dagger blade is a twist in the bevels, be it from grinding or heating. One of the first things I do with a dagger is point the tip straight at my eye and sight down the blade to see of the edges match up with the middle of the exact ricasso block down their entire length, if they dont it will be very easy to see looking at it like this.
So can I scare you in any other ways
