- Sep 17, 2007
A couple days back, I decided to sand down the annoying sharp lip that ran along the lock-bar cut-out on my Medford Marauder.
Took the pocket clip off to do so.
While I was drying it after washing the grit away, the Loctite loosened in the pivot, so I decided to open the whole thing up.
Sadly, one of the screws used to hold the pocket-clip in place was stripped on the end; you could get it to engage the threads of the nut just barely, but if you tightened it much, it spun. I guess Loctite would hold it in, but that seemed lame.
So yesterday, I went and bought new screws at Fastenal.
Then I came home, and voided the already voided warranty all to hell, and then some!!!
Lock-bar face looks to be carbidized:
More voiding!
Put it back together, and the colours were kind of neat:
Took a couple of pics at the gym with my practice sap, and the gloves I use on the bag:
Well, the action wasn't as nice as before, so I went to the gun store and bought some choke tube lube.
Opened it back up, lubed the pivot and washers, and reassembled after fiddling with the clip, heating it in an alcohol flame.
Reassembled, and the action is better. Found out that when I got it, they had not tightened the screw fully in the standoff behind the pivot, allowing for even smoother/easier opening and closing.
I tightened it all the way though, as this makes it even more Canada legal...good luck flicking it now.
With the new, longer clip screws (that I cut to length), it is on there better than ever now.
Used Teflon tape to keep the pivot screw from backing out too easily now that the Loctite has been removed...makes it easy to disassemble whenever I feel like it in the future.
So yeah, happier with it now, and I guess that also answers the question about what I think of "not being able to disassemble it."
More voiding!
