Sebenza needs an update
I'd really like to see an updated Sebenza. It's such a clean looking, simple knife. If they adopted some of the new tech from the Inkosi like the ceramic detent ball, oversized washers and pocket clip position, but kept the bushing pivot and overall design, I think it would be a knockout. Hopefully they will introduce a model like this next year since it is the tenth anniversary of the 21.
my large CF sebenza 21 has a ceramic detent. in fact i think they all do now.
you can choose between a 21 or inkosi, why update one to be like the other? doesnt make sense to me. also they have lots of new designs as of recent.
really dont see the point here.
would be great to see some more new models. but i dont think they are hurting for sales, but they would sell some new models most likely.
Maybe he likes the design shape of the 21 but the features of the Inkosi? I personally don't like the finger groves so maybe that is what he is getting at.
That is how I read it. I am not fond of the finger grooves either.
Hello
I would like to see a mid-size Sebenza so to fit between the small and large.
And maybe to see a different blade shape more like a drop point. I think this combination would work very well.
Soon, hopefully, I will be able to get an Insigno blade to see what all the fuss is about:)
Take care
Anthony
Both the 21 and Inkosi have a ceramic ball for the detent. However, on the Inkosi the ceramic ball is used as the lock interface against the blade, where as on the 21, the lock bar is actually against the blade. Perhaps that's what the OP meant about new tech. I know there are pics around the forum which show close ups of these two interfaces. You'll see the difference.
BTW the Umnumzaan and the 25 both use the ceramic ball as the lock interface against the blade as well.
I personally love the 21 the way it is with just a few small adjustments. The extra hole near the lanyard hole would love to see it gone.
Second and this one i cannot stress enough would love to see a different pattern like the Wilson Combat. Maybe something like the LDC sebenza pattern on handles (aka loke TAD edition in a way)
Larger washers for sure.
But MOST OF ALL at least an option to buy as an accessory a 3D pattern clip (similar to Mnandi clip) for Sebenza/Inkosi/Umnumzaan.
The clip idea would be to have same width as current spring clip but top face to have groves possible like Mnandi. Top clip flat with design lines and bottom either exact shape as Mnandi or if you are looking at the clip from the side bottom portion to be milled in shape of speing clip. The double bent is simply best functional clip period just not much eye candy like Mnandi.
The only change I'd like to see in the 21 is the pocket clip moved off the lockbar.
I'm on the fence about a blade steel change. I love 204p, but am also appreciative the popeties held by S35VN--mostly that it's easier for me to sharpen with my relatively limited skills.
I'm unclear why the 21 couldn't have a ceramic ball as a lock interface like the inkosi. Is there a technical reason? Is there some people who think there's a benefit to not designing it this way? Same for the pocket clip placement. I think the Inkosi is superior in pocket clip location.
Regarding the handle and blade shape, I think that's personal preference but I do like the looks of the Inkosi. What I don't like about the Inkosi is lack of a pivot bushing. To me, the pivot bushing is what makes the sebenza special relative to most other folding knives.
I'd like to see a pivot bushing offered as an option for every folding knife in the CRK lineup. Bushing-based Umnumzaan. Bushing-based Inkosi. Sign me up!! Still keep the non-bushing versions for people that prefer being able to loc-tite and micromanage their pivot tightness.
I would think a ceramic ball would crack when you whip the blade out and it contacts the blade tang. I've seen ceramic crack before but tbo their are different grades for ceramic and I assume crk uses the highest grade for the application. I'm just puzzled why they would use it for that function tho.
I come across many ceramic bearings at my job. The balls CRK is using are the ceramic balls from inside ceramic ball bearings. I can tell you, a bearing will fail, due to failure of the metal bearing race, and the motor, pump, or generator will chew the bearing race and even the axle to peices, but those little grey balls remain perfect. The inside of the machine will look like a bomb went off, but the ceramic balls will all look brand new, strewn about the inside of the windings etc.
They are incredibly durable.
Honestly my Inkosi is even way smoother than my 21s. With a knife that smooth a pivot bushing is hardly necessary.
Sounds more that rather than an updated Sebenza you want an Inkosi with a bushing.
agreed about the blade steel. i feel like a knife that is around $400 shouldn't be using the same steel as knives that are around $100. step up your game CRK.
I think s35vn is a great steel. Its ideal for cutlery and I don't feel lacking at all when I get it. To me it is just as much a high quality steel as m390 or M4 or whatever.
What happened is that s35vn became so desireable that it began appearing on less expensive knives as a marketing technique. Since s35vn became a household name knife for a good steel many steel snobs feel like it is too pedestrian.
Though I am happy with 154cm so what do I know.
oh ok i didn't know that. makes me feel better about it. thanks.
