UnknownVT said:Don't most of us here sharpen our knives far more often than necessary?
If so then ipso facto - ALL of those knives have edges that OUTLAST our actual usage.....
I know that sounds like a silly example -
but it is simple FACT.
I think a lot of people put way too much emphasis on the steel, and actually think
great steel = great blade
Nothing could be further from the truth.
here's another really silly example -
take the current "best" steel - whatever you like - S30V, VG10, BG42, 154CM - properly hardened and heat treated -
sharpen to whatever favorite angle like 20deg per side (40deg total).
WoW! great blade huh?
Yes.... it will be "hair popping" sharp, and score paper......
BUT what if the steel stock was 1" thick?
Does anyone still think that's a great knife blade?
I have read many reports where a SAK blade with its less than premium/exotic steel out cut other blades of "superior" steels -
I've done it myself to prove it - it easily out cut blades of "superior" steel - and these were well respected knives and not some junkers..........
Please take a look at some ad-hoc cutting tests in this thread:
Convexed Edge
Victorinox SAKs are "best" in the opinion of some because they simply perform -
in actual real use,
and not just by specifications.....
But if it's fancy material that's wanted -
why not have customized handles?
Vincent
http://UnknownVT2005.cjb.net
http://UnknownVT.cjb.net
http://UnknownVincent.cjb.net
I knew VT would show up here eventually.
However, IF there was a vic soldier like I specified, the blade geometry would be the same, BUT you would have better steel and Ti sides to boot. That would COMMAND sebenza-like status and an equal demand and price.
I see geometry as sort of irrelevant becasue I only buy knives with thin blades and I convex them anyway, including all my traditional SJs and SAKs, so they all cut the same, but my D2 and S30V and VG10 blades last many times longer between sharpenings. So the steel does matter, at least for me.
My opinion is that the smaller and thinner the blade, the harder the steel (steel type, tempered to maxium all-around performance) you want. A big thick knife will not slice well anyway, so why not use a softer (type of) steel that is cheaper and can put up with impacts better?
The one thing that makes SAKs better than anything else is the what you get for the price. But "sebenza-like" in my mind means overkill for 99% of a knife's use. It has to be desired beyond its pure utility.
