- Feb 18, 2016
Very cool. What are the dimensions of this anvil again? Weight? Seems like the perfect little bladesmith anvil
The go ahead was given a couple months ago to proceed with the first batch after Stacy's testing. The final molds will be pour-tested this week, the main batch should be poured next week, with heat treating the week after(hopefully). I expect to have them in mid April.
Stacy, could you give the height dimensions for the 2x12 you used for the stand, and what thickness plywood at the bottom? I'll probably go with a 2x12 for the base so I will make the dimension adjustments on my end.
Charles
I believe he said about $300Man, I want one!!
What will the price be?
Just to post a bit more about using smaller anvils:
The base is everything in a small anvil. If the base is solid, the anvil will work well. If the base isn't solid, the anvil will transfer much less of hammer energy to the workpiece ( knife blade). Just sitting an anvil on a stump isn't making it solid. It has to contact the base completely and be locked down on it hard. Any ability to bounce … even if the bounce is a few thousandths of an inch … will make it less efficient. The reason people like a BIG anvil is it uses gravity to repel this bounce. A small anvil can work fine as long as the base has sufficient weight and will not absorb energy. The second thing a base needs is solid construction. That is why a big slice of a tree trunk was always the choice. It is solid all the way through. When making a base out of wood, use large size wood. 2X12 is a minimum. Many are made from 6X6 timbers or 12X12 timbers. Bolt/screw everything together solid. Use glue between any layers and joints. Bolt the anvil down on the base.
Another base that works well is a large pillar of concrete. Use anything from a drywall bucket, to a large wash tub or metal drum and fill it with concrete to within 4" of the top where the anvil will sit. Make up a plate of steel with holes that match the anvil feet so it can bolt the anvil down to it. Use long 1/2" or 3/4" bolts (about 8" works good) and put a nut on each, drop through the holes in the plate, and put a nut on the other side, leaving sufficient bolt sticking out so the anvil could be mounted. Check that the anvil fits over the threaded ends of the bolts properly. You can tack weld the bolts in place from the bottom side, but there isn't any need to. Set the riser plate on your concrete tub and set the anvil temporarily on it. Just screw the top nuts down lightly on the anvil feet ( use large washers if needed). Adjust the nuts on both sides of the plate so the base plate is level. At this point the anvil is sitting on a plate of steel resting on legs that are about 4-5 inches long. When everything is right and level, pour in more concrete to come up to the metal plate. When set, remove the anvil, clean things up, and set the anvil back in place while it cures for a couple days. Then lock the anvil down solid to the base plate. You will have made an anvil base weighing anywhere for 100 to 200 pounds. Your little anvil will now be a big anvil.
Sample from the second foundry. About the only thing different is the label on the side. Both use C50, with HRC target of 53-58. An update on the first batch is that they have been poured, and are currently in their initial cleanup. Hopefully they will ship soon and be ready by mid-May.
