Jsega51
- Feb 11, 2015
How many calories are you going to expend cleaning a squirrel with a 14” knife that weighs 2 pounds?
A knife isn’t necessary to clean a squirrel, their skin is surprisingly easy to peel off.
I have a little bit of experience with these things...Well I’m sure I’d be doing more fine cutting tasks than I would be cutting down trees. I wouldn’t exactly be building a log cabin… maybe I make a lean-to with some branches and call it a day.
Not my point. My point is, knives are more often used for fine to medium tasks, not so often for chopping down trees.A knife isn’t necessary to clean a squirrel, their skin is surprisingly easy to peel off.
This guy gets it. No log cabins necessary.I have a little bit of experience with these things...
A lean-to absolutely has to be closed in on three sides. It also helps to retain heat; if you close off the opening as much as possible. Put your fire at the opening, cut pine boughs to get off the ground (and build your roof and walls!).
You might just survive...
Already tried splainin that lolA knife isn’t necessary to clean a squirrel, their skin is surprisingly easy to peel off.
What fine task is in your mind that need be done in "survival" that a larger knife won't do?Not my point. My point is, knives are more often used for fine to medium tasks, not so often for chopping down trees.
Everyone likes to fantasize about building log cabins with their fixed blade but it just isn’t practical. You don’t need to chop down a tree to survive in the wilderness.
How are you going to catch the squirrel? Going to throw the 14” knife at one?Already tried splainin that lol
Repetition sometimes gets the point across.Already tried splainin that lol
In what survival scenario would I need to chop down several trees? Talk about a waste of energy.In a survival situation, all your preconceived notions are thrown out the window. That’s what you’re not seeing. It doesn’t matter what knife you have, you have to use it for everything.
Your choice isn’t wrong. My choice isn’t wrong. No one’s choice is wrong, yet here you are as expected pointing out situations just to go against peoples choices.
Better than “life or death timber production”. I’m not setting up a saw mill here.What fine task is in your mind that need be done in "survival" that a larger knife won't do?
Life or death spoon carving?
Branches. I don’t need a 14” knife to cut branches.You making a long term shelter out of the sticks you find on the ground?
Okay you want a scenario? Here you go:If we are talking about a knife in the woods, somewhere in north america, is it winter? Do you need a night long lasting fire to survive? Going after dead standing wood is much easier with a larger knife.
This question is so open ended. Knife in death valley? Knife in rural alaska? Winter, summer, spring in the north (flooding from snow melt), I could go on and on. My knife choice would change a bit depending on scenerio.
Like I said, wooded north america I'd go 8" to 13". We aren't talking about "surviving" a 3 hour hike to the road, right?
Weeks or months? I'll stick with my choice.
Don’t be ironic. Many of you came here to comment for the purpose of arguing. Don’t clutch your pearls when someone fires back.But it would work for many others correct? Do you see how you just want to argue?
What kind of fine cutting tasks do see yourself performing where your 1/8" thick LT Wright GNS prevails in a survival scenario?Well I’m sure I’d be doing more fine cutting tasks than I would be cutting down trees. I wouldn’t exactly be building a log cabin… maybe I make a lean-to with some branches and call it a day.
What length of blade would you MOST prefer for use in a survival scenario? You’re about to pack up and embark on a journey to the wilderness where you will need to live for an extended time (several weeks or more). You are able to choose ONE knife to take with you, which is a fixed blade. No axe, no hatchet, no other edged tool or weapon. Just your knife.
