- Dec 17, 2007
wow its fine
wow its fine
I strongly disagree with your bolded statement. He can describe the condition of the knife all he wants, but he can't tell me things like the angle of the lockface to lock bar, or if the liner lock is slightly bent, or if forward pressure on the liner lock has been reduced from OEM. Condition descriptions can only go so far, beyond that you have to look at what the knife has been through.
STATEMENT A: I can't look at "what it's been through" or the story of what it's been through, all I can see is the knife. You buy the knife, not the story.
STATEMENT B: In this case the guy was upfront about the condition.
tipoc
A spine whack and pounding the spine on a hard surface are two different things. I can spine whack my SAK hard enough to dent wood without the slip joint giving in, so I highly doubt the same thing would hurt a quality folder.
I doubt it....
I have an SAK and a few other slip joints and they give in very easy, it doesn't take much to defeat them.
Okay, video incoming.
No, not the spine whack thread! It is like a case of herpes. It keeps coming back, festering shanker that it is! Do not buy a whacked knife!
I did a spine whack test on the BF Sebenza pass around.
http://www.bladeforums.com/forums/showpost.php?p=8152244&postcount=84
This resulted in a flesh wound to my spine. However the mole did not grow back.![]()
That should be interesting to see them give and snap back into place... That is what they do most of the time because the spring gives then snaps the blade back..
But I can hit mine and case them to fail and hold easy with a snap of my wrist against wood.
I hit them a lot harder than that.
I snap my wrist when I do it.
Watch my video again and you will see.![]()
I'm sure you do, but my point was that what I was just doing is all the harder it needs to be to check the lock stability, and there is nothing detrimental about it. Spine whacking only becomes abuse when you go overboard.
I could whack the thing at least twice as hard and it wouldn't close, but my daughter is asleep behind me and I didn't want to be too loud.
I understand that.![]()
My initial post was directed to people that think a simple spine whack is going to destroy a knife, and that you should never, ever do it.
I just felt obligated to prove that I could dent wood with a SAK spine whack, since you called me out on it.
It is a valid test for lock strength so show how strong the lock can be . . .
There is a reason you don't do destructive tests on things you use.
