- Dec 31, 2005
(Weird double post ?) not sure what happened ...
Might as well add this ... the difficulty on mag feed shotguns is the "mag change" in terms of military use ... the shells don't sit easily in the mags as there is no easy way for the lips on the mags to hold them and still enable reliable feeding ... certainly compared to the "shoulder" on a rifle bullet which works well with the mag lips to enable a secure hold ... the shells have no taper to enable a similar design ... so they can slide forward and cause mag feed issues ... and hence the popularity of the large drum mags which enable enough rounds to be available without a change but then the weapon is really heavy ( you just have to pick up the same number of shells in ammo boxes to realise this ) ... so all told if you might need more than 10 rounds and want a light pointable shotgun ... tube feed options are the way to go ...:thumbup:
