Also, I do not understand why the serrations on a semi-serrated knife are at the control part of the blade where the plain edge should be.
P.S. Of course there is people who do not have time or desire to keep their knives perfectly sharp - police, military, fire fighter etc. They may never sharpen knife and may not know howto do this but steel need cutting-power. So for this kind of use scenario serration is prefferable. But knife enthusiasts like me who looking for excuse to resharpen knife serration is noncense.
Galeno said:Do you think the PE would have served better as a utility knife?
Jeff Clark said:The primary reason for black blades and serrated blades is to appeal to unsophisticated buyers without knife sharpening experience. (This is not the only reason and these are not the only buyers, but they are the large majority). Most of these buyers are young males who think these blades look tough and more agressive. Uncoated plain edge blades appeal more to buyers who like a blade that is easier to sharpen and which allows more subtle cutting options than sawing things apart (this is a sophisticated minority). So serrated blades are often black blades and plain edge blades are often uncoated.
nozh2002 said:I am not buying any serrated knives.
On my experience serration does not make rope cut better - it dos not cut anithyng better. Perfectly sharpened edge will outcut any serration and the only reason for it that it keep sawing much longer then Plane Edge keep cutting - it will stop cutting when dull.
This is why all cheap knives have serration (I mean $1 for 10 kind of cheap) like chinese kitchen knives which continue sawing over years without sharpening having worse steel possible - you just need to applay more forse ans it will rip apart everithing.
This is why all expensive knives - like custom etc never have serration (over $300).
Best example - Strider SNG never serrated and Buck Strider with 420HC - serrated.
Thanks, Vassili.
Capt. Carl said:I don't think there is any need. A good plain edge knife will cut almost anything as well and I do not think semi-serrated knives have a long enough serration to be effective.
Capt. Carl said:Also, I do not understand why the serrations on a semi-serrated knife are at the control part of the blade where the plain edge should be.
beefangusbeef said:That is a good point, but in emergency situations you can cut rope quicker with serrations than pe, same for clothing, rucks and other abrasive material that even a sharp pe might just glance over with a quick flick. The serrations dig in deep and quick. Also, they are nice when you are cutting LOTS of rope, say 100 or more swiss seats![]()
nozh2002 said:Again on my experience it is not true, serration does not cut rope or enything else better then sharpened plane edge. Is it emergency situation or not, does not matter. However if you do not know or will or car to sharpen you knife - and majority of people do then you better relay on serration which will rip through for sure if you put a lot of force to it because it tends to stuck in the rope - cutting is much harder.
If rope under strain plane edge will cut it just perfect, way better then serrated blade. I would say that serration can cut rope under strain and it is almost impossible to cut rope which are not under starain with serrated blade. So I may agree that serration cut rope ander strain better then same serration blade cut same rope without strain, but not better then plane edge.
However if you need to cut a lot of rope and not able to touch up blade then serration will be prefferable, but you'll be really tiered. However you may check how Busse cutting rope and they always plane!
Now expensive knives in general better then cheap, and expensive knives in general does not have serration except Green Beret by CR, which is for military and in general they have no time and skills to sharpen it properly.
Thanks, Vassili.
Galeno said:This is some what of a stupid question. Oh well!
I just purchased a bm rukus with partial serrations. I've never really owned a quality knife with half serrations. Do you think the PE would have served better as a utility knife?
Also, it seems PE benchmade knives rarely come with black coating. Why is this?
Thank in advance.![]()
Pete1977 said:I think that PE or CE work better for general utility applications than a fully SE knife, and between PE or CE, I find that the PE is more useful. but, as it has been stated before, it mainly depends on what you are going to use the knife for. a PE and CE open boxes and letters with the same efficiency. you can cut twine, open clamshell packs, cut fruit and meat, halve a sandwich, etc. with either a PE or a CE blade.
my suggestion would be to look into the spyderco sharpmaker, to sharpen your knife. it easily sharpens fully serrated knives, plain edges, and 50/50 edges with minimal effort. it doesn't take much to learn to use it, and it is great for quick touch ups, which I suggest doing with a SE or CE blade, to keep the serrations from becoming too dull. Quick touch ups often will save the trouble of having to completely sharpen the serrated part of your knife, which can be a chore.
peter
