Nosmo said:
This is becoming more and more of a problem. I recently purchased a custom in S30v and it's edge had a 17 degree angle. However the thickness of the steel just behind this edge was over 1/16th of an inch. Needless to say it would not cut anything and needed allot of work.
This is a common "tactical" profile, mainly due to using unsuitable steels which simply don't have the necessary durabilty which force heavy profiles.
db said:
However, a large convex edge probably doesn't look right on all knives.
It doesn't look right on any knife unless you need it to function as a splitting wedge thus it has a place on some chopping blades which need to force materials apart violently as otherwise they will bind. Aside from that consideration, the edge profile should be minimal in both thickness and width as the force is concentrated at the edge. As Thom noted, wide bevels are mainly a side effect of too thick edges, use a more optimal primary grind. There is no need to be sharpening a wide strip of steel, only a few thousands is actually cutting anything.
OleyFermo said:
Really enjoy reading your reviews. It's great to see someone putting as much work as you do into objective testing. Keep up the good work.
Thanks, I was talking to Matt Lamey awhile back, really like the looks of the Fikes style blades has has done. Though I find cord wraps abrasive in extended use, guess I need to do more work.
frugalweaver said:
Concave edges are easier to touch up for the novice.
I don't think you can produce a concave edge by hand, hollow primary grinds are easier for anyone to sharpen as there is less metal to remove and in extremes basically have included angle jigs. They are better than convex blades at somethings (slicing cardboard) but not at others (deep cuts in woods). I think you could argue convex edges are superior in general, but in some applications the optimal curvture is so shallow it is basically flat and a multi-bevel flat profile is very competitive and much easier to apply.
I had a guy try to argue with me that his knife sharpened on 120 grit sandpaper was sharper than my razor honed polished edge. His proof was cutting a 1/2 inch rope in a half dozen saw cuts.
For slicing it requires less force, or takes less edge with the same force. It will also cut for far longer. I don't see how you could not call it sharper. Sharpness for push cuts and slices are at odds in terms of optimal grit finish. Many makers will go somewhere inbetween, the fine india hone is really popular with a lot of makers as it has enough aggression to still slice well but doesn't hold up on fine push cuts.
-Cliff
